Compiling the snippet:
!$omp target
write(*,*)1234
!$omp end target
generates the error:
ifx -qopenmp -fopenmp-targets=spir64 -g -traceback -c tbp.F90
tbp.F90(53): error #8945: Generalized I/O not supported in an offload region.
write(*,*)1234
compilation aborted for tbp.F90 (code 1)
Note: Simple write statements to standard output from an OpenACC offload region are supported by the Nvidia (PGI) compiler.
Questions:
- Is it possible to have debugging output in a target region of a Fortran program using OpenMP offload and compiling with ifx?
- If this is not currently supported, are there plans for ifx to support simple output from target regions in the future?
- Any other suggestions for inspecting the values of variables in running device code?
Thank you,
John
This snippet compiles for me .
$ cat snippet.f90
program snippet
!$omp target
x = 1234.
print *, x
print *, 1234
!$omp end target
stop
end
$ ifx -qopenmp -fopenmp-targets=spir64 snippet.f90
$ ifx -what --version
ifx (IFORT) 2022.0.0 20211123
Copyright (C) 1985-2021 Intel Corporation. All rights reserved.
Thanks for looking into this. It must be because I was using a write(*,*) instead of print*
If I change one of the prints in your snippet I get:
$ cat snip.F90
program snippet
!$omp target
x = 1234.
write(*,*) x
print *, 1234
!$omp end target
stop
end
$ ifx -qopenmp -fopenmp-targets=spir64 snip.F90
snip.F90(4): error #8945: Generalized I/O not supported in an offload region.
write(*,*) x
compilation aborted for snip.F90 (code 1)
Mystery solved, thank you.
John
You're welcome.
I tried variations of the write, like write(6,*) and write(6,5). All got that same message. But print does compile.
Of course, this IS a bug. If one is accepted, all of these should be.
According to the Fortran developers, "At this time, the only I/O we’re allowing in an offload region is 'print *' and even that is limited to numeric and character strings."
I'll add that tidbit to the Porting Guide for ifort Users to ifx.
Thanks all for following up. For what it's worth, write(*,*) and print* are analogous. But I'm in good shape, now that I know the rule.
Also FWIW, I think output of numeric and character strings to stdout from print and write(*,*) is all that the Nvidia compiler supports from an offload region.
Barbara,
What about
PRINT '("Value=",F6.2)', 123.456
(my oneAPI system is not fired up)
Jim Dempsey
Or
WRITE(CharacterVariable, '("Value=",F6.2)') 123.456
Jim Dempsey
Doesn't look like it inside an OpenMP TARGET region.
+ ifx -qopenmp -fopenmp-targets=spir64 snippet.f90
snippet.f90(7): error #8945: Generalized I/O not supported in an offload region.
snippet.f90(8): error #8945: Generalized I/O not supported in an offload region.
compilation aborted for snippet.f90 (code 1)
