29435 Discussions
libiomp5.so problem after updating to Ubuntu 9.04
lessonfree
I just update my Ubuntu to 9.04. and I'm getting message after
./t62
./t62: error while loading shared libraries: libiomp5.so: cannot open shared object file: No such file or directory
no errors during compilation(ifort -openmp -o t62 t62.f90)
I'm using 11.0 / 074
libiomp5.so seems to be in directory /opt/intel/Compiler/11.0/074/lib/intel64
TimP
Did you set LD_LIBRARY_PATH (recommended way is by source /opt/intel/Compiler/11.0/074/bin/ifortvars.sh,
same as when compiling).
Maybe you have an old fixed path in your setup.
lessonfree
Quoting - tim18
It works until I restart the computer. How to make it permanent?
lessonfree
Quoting - tim18
Secondly. If I upgraded OS, does it mean that all my libraries were connected to the old core?
TimP
Quoting - lessonfree
Maybe you had the source command for the compiler in a login script, such as .profile. Such things might be disturbed with the upgrade. If you upgraded the compiler, you may have several versions installed; if you were pointing to an older version of the shared libraries at run time, it may have worked up to a point.
If you used another mechanism, such as ldconfig, it very likely got changed without recognizing Intel software in the OS upgrade. You would have to update it with the current Intel library directory. I suppose it's easy to get messed up with software upgrades if using ldconfig.
lessonfree
Quoting - tim18
how to find out? and how fix it?
lessonfree
Quoting - tim18
I did not upgrade the compiler, I have upgrade only for Ubuntu(to 9.04). How about reinstallation of the compiler? If so how to remove it?
I'm probably asking too many questions, but I really do not know much about Linux.
lessonfree
Quoting - tim18
file ld.so.conf in /etc
consist only one line
include /etc/ld.so.conf.d/*.conf
