makedepf90 for Windows
geoff_tolton
Hi
I have been using makedepf90 on my Unix box for sorting
out compilation order dependencies where modules are concerned. Does anyone have a version for Windows?
Many thanks
Geoff
Jugoslav_Dujic
Valued Contributor II
Don't know a straight answer for your question. If you're using CVF, it has built-in capability you need -- if you add all your files into a project workspace, do a Build/Update all dependencies, you can export a NMAKE-compatible makefile using Project/Export Makefile option. Since it's autogenerated, it may be uglier than you want but all the stuff is there.
Jugoslav
