Hello: I'm trying to install ncl-ncarg-5.2 with Intel compilers.
I do whatever I found in the page (ncl and Intel), but I still havn't all the files that i supposed to.
I attach the make-output log.
The command grep SYSTEM_INCLUDE Makefile returns
SYSTEM_INCLUDE = "LINUX"
i think the problem is with the flags or something with Intel fortran or icc compilers.
Wich flags I suppose to use?
I hope you can help me resolve this.
Unless I'm misled by the Spanish, your attachment says you didn't set read permission on your include directory. I don't see how you can attribute this to flag settings or blame the compilers.
Hi Tim, thanks for the answer. The directory have the read permission...
What i did was start all over again....
I compare the list of files that I must have, I don't have them all....
I read the make-output log and I saw warnings and errors like...
/usr/include/X11/Xlib.h(81): error: invalid redeclaration of type name "wchar_t" (declared at line 54 of "/opt/intel/Compiler/11.1/072/include/stddef.h")
typedef unsigned long wchar_t;
compilation aborted for xdevice.c (code 2)
make[5]: *** [xdevice.o] Error 2
icc -O -I../../../.././include -I/usr/X11R6 -DLinux -DMAJOR=2 -DSYSV -D_POSIX_SOURCE -D_XOPEN_SOURCE -DByteSwapped -DNeedFuncProto -c -o s_gopks.o s_gopks.c
s_gopks.c(45): warning #167: argument of type "const char *" is incompatible with parameter of type "void *"
if( !strcmp( err_file, "stderr" ) || !strcmp( err_file, "stdout" ) ) {
I attach the new make-output log, and in the configuration file (LINUX) I have an error in CtoFLibraries, now I set that value with -lifcore, I attach the LINUX file again..
These look like legitimate complaints from the compiler, a possible indication that the source code was never checked for such errors (it may have been made to compile only with older compilers which didn't check). As this is a question of C syntax, it might better be followed up on the C/C++ forum, if there is no forum for this application. Is there an updated version consistent with the level of gcc which you have installed on your system?
hi Tim, thanks for the answer.
I can't use gcc, I must use intel compilers, because I compile WRF, netcdf and WPS with Intel, and this tool must be compiled with Intel.
I send an email to the application forum as well, I still waiting for response.
Thanks..
Bye
Thanks..
Bye
You can't use icc without a gcc installation. If your source code is not consistent with the gcc as well as icc, you are likely to see these difficulties. Much of the syntax checking is due to improvements in gcc over the last 5 years.
![](/skins/images/1FC86CD46823E418D1E2B7B4DC10231C/responsive_peak/images/icon_anonymous_message.png)
Topic Options
