29566 Discussions
oneapi-cli sample project creation fails for fortran project
keyurjoshi
     I am using Ubuntu 20.04 on a Intel® Core™ i9-7900X CPU @ 3.30GHz × 20 machine with 3 Nvidia Titan Xp GPUs. I have installed
1. one API base toolkit and
2. one API HPC toolkit.
I wanted to test the installation with command-line interface sample projects using oneapi-cli.
The fortran project which is the only one project sample available for fortran - "OpenMP-offload-training" fails abruptly with the following message.
       "2022/02/17 15:26:56 unexpected EOF"
I could build cpp project, but fortran one fails.
Is that something to do with installation or something is wrong with my configuration.
I work mainly in fortran and it is critical for me to have ifort and mpifort working correctly.
Any help will be appreciated.
keyur
VarshaS_Intel
Thanks for reporting to us.
We are working on your issue. We will get back to you soon.
Meanwhile, could you please try with the sample codes from Github? Try to git-clone and you can use the sample codes. Please find the below command for git cloning with the Intel oneAPI samples.
git clone https://github.com/oneapi-src/oneAPI-samples.git
Please find the below screenshot for more information:
Please find the below path for the "OpenMP-offload-training" code:
oneAPI-samples/DirectProgramming/Fortran/Jupyter/OpenMP-offload-training
Thanks & Regards,
Varsha
VarshaS_Intel
We are working on your issue internally and will get back to you soon.
Thanks & Regards,
Varsha
Ron_Green
This is Linux, correct?
To test the compiler, create this simple fortran program, name it 'hello.f90'
program
 print*, "hello"
end program
Next,
source /opt/intel/oneapi/setvars.sh
then
ifort -o hello hello.f90
./hello
 That should work.  If not, show us the error you get from the above.
Next, let's test your MPI.  Here is a sample to test, name it 'hello_mpi.f90'
PROGRAM hello_world_mpi
include 'mpif.h'
integer process_Rank, size_Of_Cluster, ierror, tag
call MPI_INIT(ierror)
call MPI_COMM_SIZE(MPI_COMM_WORLD, size_Of_Cluster, ierror)
call MPI_COMM_RANK(MPI_COMM_WORLD, process_Rank, ierror)
print *, 'Hello World from rank: ', process_Rank, 'of ', size_Of_Cluster,' total ranks'
call MPI_FINALIZE(ierror)
END PROGRAM
Compile it
mpiifort -o hello_mpi hello_mpi.f90
 And run with 1 rank
mpirun -n 1 ./hello_mpi
 Hello World from rank:            0 of            1 total ranks
Then run with, oh, say 4 ranks
mpirun -n 4 ./hello_mpi
 Hello World from rank:            3 of            4 total ranks
 Hello World from rank:            0 of            4 total ranks
 Hello World from rank:            2 of            4 total ranks
 Hello World from rank:            1 of            4 total ranks
keyurjoshi
Thanks Ron,
ifort is fine. I have tested it with other simple fortran programs.
mpiifort compiles the program, but throws runtime error segmentation fault.
$ mpirun -n 4 ./hello_mpi
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 39556 RUNNING AT tt433gpu1
= KILLED BY SIGNAL: 9 (Killed)
= RANK 1 PID 39557 RUNNING AT tt433gpu1
= KILLED BY SIGNAL: 11 (Segmentation fault)
= RANK 2 PID 39558 RUNNING AT tt433gpu1
= RANK 3 PID 39559 RUNNING AT tt433gpu1
keyurjoshi
Further, I tried debugging the application with gdb it seems it fails in MPI_INIT call itself.
 I built it with debug flag
mpiifort -g -O0 -o hello_mpi hello_mpi.f90
and
$ mpirun -n 1 gdb ./hello_mpi
GNU gdb (Ubuntu 9.2-0ubuntu1~20.04.1) 9.2
Copyright (C) 2020 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from ./hello_mpi...
(gdb) b hello_world_mpi
Breakpoint 1 at 0x4038dc: file hello_mpi.f90, line 4.
(gdb) list
1 PROGRAM hello_world_mpi
2 include 'mpif.h'
3 integer process_Rank, size_Of_Cluster, ierror, tag
4 call MPI_INIT(ierror)
5 call MPI_COMM_SIZE(MPI_COMM_WORLD, size_Of_Cluster, ierror)
6 call MPI_COMM_RANK(MPI_COMM_WORLD, process_Rank, ierror)
7 print *, 'Hello World from rank: ', process_Rank, 'of ', size_Of_Cluster,' total ranks'
8 call MPI_FINALIZE(ierror)
9 END PROGRAM hello_world_mpi
(gdb) r
Starting program: /home/smec17045/hello_mpi
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Breakpoint 1, hello_world_mpi () at hello_mpi.f90:4
(gdb) n
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff5710131 in ofi_cq_sreadfrom ()
from /opt/intel/oneapi/mpi/2021.5.1//libfabric/lib/prov/libsockets-fi.so
(gdb)
