29229 Discussions
pass array of types to com server
ancientcoder
We have a VB dotnet app using a com server we are building. We need to pass in an array of types to a method. The types contain arrays of doubles.
We have succeeded in passing in one type using this code:
Dim
ar_LmdaPar(2) As Double '3 elements
Dim ar_MuPar(1) As Double '2 elements
Dim ar_CpPar(3) As Double '4 elements
Dim mw As Double
ar_LmdaPar(0) = 0.1
ar_LmdaPar(1) = 0.2
ar_LmdaPar(2) = 0.3
ar_MuPar(0) = 0.11
ar_MuPar(1) = 0.22
ar_CpPar(0) = 0.1111
ar_CpPar(1) = 0.2222
ar_CpPar(2) = 0.3333
ar_CpPar(3) = 0.4444
mw = 0.7777
Dim oneGas As AdderLib.GasKind
oneGas =
New AdderLib.GasKind
oneGas.GasKind(ar_LmdaPar, ar_MuPar, ar_CpPar, mw)
But when I try to create an array of the type GasKind using the code below and load it I get the error
"Object reference not set to an instance of an object"
dim
gasArray() As AdderLib.GasKind
gasArray(0) =
New AdderLib.GasKind --- this line generates the error
gasArray(0).GasKind(ar_LmdaPar, ar_MuPar, ar_CpPar, mw)
The arrays all are fine as well as the double mw
I tried creating the instance then assigning it to the first element of the array like
gasArray(0) = oneGas
and still got the same error
Here is the fortran generateed by the wizard:
module
IGasKind_Methods
! These routines get implemented by the user
interface
function IGasKind_GasKind( ObjectData ,&
LmdaPar,&
MuPar,&
CpPar,&
Mw)
result (hresult)
use GasKind_Types
type(GasKind_InstanceData) ObjectData
!dec$ attributes reference :: ObjectData
REAL(8), intent(inout) :: LmdaPar
DIMENSION LmdaPar(1:3)
REAL(8), intent(inout) :: MuPar
DIMENSION MuPar(1:2)
REAL(8), intent(inout) :: CpPar
DIMENSION CpPar(1:4)
REAL(8), intent(inout) :: Mw
integer(long) hresult
end function
end interface
! Local definition of SysStringLen
interface
pure integer*4 function SysStringLen_Local(bstr);
!dec$ attributes default, stdcall, decorate, alias : 'SysStringLen' :: SysStringLen_Local
use ifwinty
integer(int_ptr_kind()), intent(in) :: bstr
!dec$ attributes value :: bstr
end function SysStringLen_Local
end interface
contains
! Wrapper functions called from the Vtbl
function $IGasKind_GasKind( pInterface ,&
LmdaPar ,&
MuPar ,&
CpPar ,&
Mw )
result (hresult)
!dec$ attributes stdcall :: $IGasKind_GasKind
use GasKind_Types
use ifcom
implicit none
type (IGasKind_Ptr) pInterface
!dec$ attributes reference :: pInterface
integer(INT_PTR_KIND()), intent(inout) :: LmdaPar
!dec$ attributes reference :: LmdaPar
integer(INT_PTR_KIND()), intent(inout) :: MuPar
!dec$ attributes reference :: MuPar
integer(INT_PTR_KIND()), intent(inout) :: CpPar
!dec$ attributes reference :: CpPar
!dec$ attributes reference :: Mw
integer i
REAL(8) f$LmdaPar(1:3)
pointer(ptr$LmdaPar, f$LmdaPar)
integer(INT_PTR_KIND()) sa$LmdaPar
!DEC$ IF .NOT. DEFINED(NOCHECK_ARRAY_)
integer dims$LmdaPar
integer lb$LmdaPar(1)
integer ub$LmdaPar(1)
integer nb$LmdaPar(1)
!DEC$ ENDIF
REAL(8) f$MuPar(1:2)
pointer(ptr$MuPar, f$MuPar)
integer(INT_PTR_KIND()) sa$MuPar
integer dims$MuPar
integer lb$MuPar(1)
integer ub$MuPar(1)
integer nb$MuPar(1)
!DEC$ ENDIF
REAL(8) f$CpPar(1:4)
pointer(ptr$CpPar, f$CpPar)
integer(INT_PTR_KIND()) sa$CpPar
integer dims$CpPar
integer lb$CpPar(1)
integer ub$CpPar(1)
integer nb$CpPar(1)
!DEC$ ENDIF
sa$LmdaPar = NULL
lb$LmdaPar = 0
ub$LmdaPar = 0
nb$LmdaPar = (/3/)
!DEC$ ENDIF
sa$MuPar = NULL
lb$MuPar = 0
ub$MuPar = 0
nb$MuPar = (/2/)
!DEC$ ENDIF
sa$CpPar = NULL
lb$CpPar = 0
ub$CpPar = 0
nb$CpPar = (/4/)
!DEC$ ENDIF
dims$LmdaPar = SafeArrayGetDim(LmdaPar)
if (dims$LmdaPar /= 1) then
hresult = E_INVALIDARG
goto 9999
end if
hresult = SafeArrayGetLBound(LmdaPar, 1, lb$LmdaPar(1))
hresult = SafeArrayGetUBound(LmdaPar, 1, ub$LmdaPar(1))
if (nb$LmdaPar(1) /= (ub$LmdaPar(1) - lb$LmdaPar(1) + 1)) then
goto 9999
end if
!DEC$ ENDIF
hresult = SafeArrayAccessData(LmdaPar, ptr$LmdaPar)
if (hresult < 0) goto 9999
sa$LmdaPar = LmdaPar
dims$MuPar = SafeArrayGetDim(MuPar)
if (dims$MuPar /= 1) then
goto 9999
end if
hresult = SafeArrayGetLBound(MuPar, 1, lb$MuPar(1))
hresult = SafeArrayGetUBound(MuPar, 1, ub$MuPar(1))
if (nb$MuPar(1) /= (ub$MuPar (1) - lb$MuPar(1) + 1)) then
goto 9999
end if
!DEC$ ENDIF
hresult = SafeArrayAccessData(MuPar, ptr$MuPar)
sa$MuPar = MuPar
dims$CpPar = SafeArrayGetDim(CpPar)
if (dims$CpPar /= 1) then
goto 9999
end if
hresult = SafeArrayGetLBound(CpPar, 1, lb$CpPar(1))
hresult = SafeArrayGetUBound(CpPar, 1, ub$CpPar(1))
if (nb$CpPar(1) /= (ub$CpPar(1) - lb$CpPar(1) + 1)) then
goto 9999
end if
!DEC$ ENDIF
hresult = SafeArrayAccessData(CpPar, ptr$CpPar)
sa$CpPar = CpPar
hresult = IGasKind_GasKind(pInterface % pInternalData % pInstanceData ,&
f$LmdaPar ,&
f$MuPar ,&
f$CpPar ,&
Mw )
9999 continue ! Cleanup code
if (sa$LmdaPar /= NULL) i = SafeArrayUnaccessData(sa$LmdaPar)
if (sa$MuPar /= NULL) i = SafeArrayUnaccessData(sa$MuPar)
if (sa$CpPar /= NULL) i = SafeArrayUnaccessData(sa$CpPar)
end function
end module
I can't seem to pass in an array of these types. We have this same code working using un-managed code but really need to have a com server.
Thanks in advance!
ancientcoder
Please ignore this post or remove it. I must have been off my meds yesterday.
I was trying to have the com server create objects to be passed back to the server.
I should have been creating arrays of structures in VB and pass those to the com server instead.
Sorry to waste your time
