- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
i am debugging a project. while debugging, i have blocked with this error:" 'file name' has triggered a breakpoint". this error is marked with a green sign, please see the attached file. also when i press the "step into" button this message is appeared:"There is no source code available for the current location".
please provide me with your advice.
Milad.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
fwiw my two bits...
ModifiedFAST.exe is the "file name" and that is the name of the EXE of your project?? so no problem there
The error seems to point to a variable on the calling arguments of TwrLoading.
do you have a break on value change or some other breakpoint related to one of the variable arguments in passed to/from TwrLoading?
Check you breakpoint list.
Isthe TwrLoading subroutine source avail?
I sometimes encounter these types of errors when jumping between debug/release and/or copying files and encounter a routine(for you it'd be TwrLoading) which might becompiled in Release and/or w/o debug information?
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
fwiw my two bits...
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
A second potential problem is where the code gets erroneously modified to what looks like a break point. In your screenshot your message stated ...break at line nnnn in ....
Using your Debug | Breakpoints look to see if you have a breakpoint placed there. Note, I did not notice the red circle on the left frame of the text window (indicating break point). When code gets modified it is typically when you store through a wayward pointer (or the debugger is confused as described in first paragraph of this message).
Jim Dempsey
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
many thanks for your helpful advice.
Milad.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
bmchenry,
milad.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
thanks for your comment,
i have checked the variables , and in this case, the message was related to variable arrangement.
Milad.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
