I have Compac visual Fortran 6.6 running on XP professional SP1. Inside Developer Studio anumber of the popup menues, such as "Add to Project" under Project do not work. No popups appear. This is a new IBM T40 Centrino. The same Compac visual Fortran 6.6 works fine on my old IBM A31P with XP Professional.
Any thoughts?
Any thoughts?
I would suggest an uninstall and reinstall. That's a symptom I haven't seen reported before.
Steve
Steve
I un-installed and re-installed CVF6.6 but non of the pull-down menues work in Developer Studio.
Do you have a project open when you are doing this? Is this a project you copied over from another system?
Try deleting the file with the .OPT file type in the project folder and restarting Developer Studio.
Steve
Steve
Non of the popups with or without a project open. I have created a entirely new project on the new system, but the popups dont work from the start. Normaly you have a popup 'recent workspaces' that works on start up but not on this system. Everything except the popups work. the compiler is fine and I can build and run and debug, just without any popups.
thanks
thanks
As for "Reload last workspace at startup", it is not checked as default. You have to go to Tools / Options... / Workspace and check for it.
Sabalan.
Sabalan.
I guess I am confused as to what you mean by a "popup" in this context. I thought you meant that none of the menu items worked.
Steve
Steve
Does Tools/Customize/Reset all menus help?
Jugoslav
Jugoslav
Topic Options
