Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Graphic Monitor crashes when loading captured frame
Cihan_S_
When analyzing a frame captured via intel GPA , it always seems to crash I cant figure out why.
Intel® INDE Graphics Frame Analyzer
Copyright: © 2007-2014 Intel Corporation. All rights reserved.
Version: 14.3.231370
Host IP: 127.0.0.1
Information of the System on which the Frame was Captured
File Capture Date: 2014/11/18
Windows 7 build 7601, 64-bit DEP enabled
Num Processors: 8
Memory: 16332MB
System BIOS: American Megatrends Inc. P1.50 (06/24/2014)
Video BIOS: 3GTX780 VB Ver 80.80.21.00.AS07 (12/17/13)
Driver 0:
     Device: NVIDIA GeForce GTX 780
     Provider: NVIDIA
     Date: 11-3-2014
     Version: 9.18.13.4465
     VendorId: 10de
     ProductId: 1004
     Stepping: a1
     No support for GPA Instrumentation
Install directory: E:\Intel\INDE\GPA\2014 R3\
Current user is in Administrators group: YES
Playback System Information
Num Processors: 8
Memory: 16332MB
Driver 0:
     Provider: NVIDIA
     Date: 11-3-2014
     VendorId: 10de
     ProductId: 1004
     Stepping: a1
Hope you guys can assist me with this,
Neal_Pierman
Valued Contributor I
I took a quick look at the error report, and see that it had problems with your textures. Do you know what texture format(s) you are using, as it may be a format that is not supported by the toolset.
Neal
Cihan_S_
The game engine utilizes the following formats
BC1
BC3
BC5
and lastly DXGI_FORMAT_BC7_UNORM
Neal_Pierman
After checking, it appears that all of these formats are supported. It would be helpful if we could at least get the frame capture file to see if we can duplicate the problem on our systems. If you are uncomfortable including the file on the forum, please send me the file via a private message.
Neal
ps-> we may also need the original program that generated the bad file as well, but let's just start with the frame capture file first
Neal_Pierman
One more question -- does this problem only occur on the NVIDIA GeForce GTX 780? In other words, have you tried this on other systems to see if it's an issue with this specific graphics hardware?
thanks!
Neal
