I have a robotic application where I want to be able to create G-Code to select and then describe each object on a 610mm x 457 region of focus. I can place 1 or more cameras within 1m and can optimize the height for the application. The ROF will be stationary at the time of image capture. I can control the lighting through curtains or adding additional lighting.
I need g-code that is accurate to the .25mm or better. Is this a reasonable expectation/target to have? What accuracy should I be able to reach reasonably?
How can I use the information on Intel Spec sheets to determine what I should expect from each camera? Does running in stereo improve accuracy and if so, by how much?
Andy
Hi AndyO,
Thank you for your post regarding your photogrammetry system! Are you by chance asking about the Intel® RealSense™ camera? If so, you will be more likely to get solutions to your questions by posting in this discussion board for Intel® RealSense™ in the link below: https://support.intelrealsense.com/hc/en-us/community/topics.
It looks like it is quite active, and I hope that you can get answers promptly.
This support forum was created to answer questions and help support collaboration regarding Intel Graphics Performance Analyzer (Intel's tool to improve a game's performance by quickly identifying problem areas), and if you have any questions about Intel GPA I would be happy to answer them!
Cheers!
![](/skins/images/BC9A7A3465121B56B278007F4EE8899F/responsive_peak/images/icon_anonymous_message.png)
