Intel® High Level Design
722 Discussions
Error in using emulator mode with SDK 20.1 for hello_world example
beiwang2003
I have quartus 19.2 and FPGA SDK 20.1. When trying to compile the OpenCL code with emulator mode:  aoc -march=emulator -o ./bin/hello_world.aocx ./device/hello_world.cl, I had the following error message in running the code. The problem is resolved by using -legacy-emulator option. Same problem and solution for SDK 19.4. My question is when do I need to use -legacy-emulator option for SDK 19.4 and beyond?  Thanks
[beiwang@della-fpga1 hello_world]$ ./bin/host
Querying platform for info:
CL_PLATFORM_NAME                         = Intel(R) FPGA SDK for OpenCL(TM)
CL_PLATFORM_VENDOR                       = Intel(R) Corporation
CL_PLATFORM_VERSION                      = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 20.1
Querying device for info:
CL_DEVICE_NAME                           = EmulatorDevice : Emulated Device
CL_DEVICE_VENDOR                         = Intel(R) Corporation
CL_DEVICE_VENDOR_ID                      = 4466
CL_DEVICE_VERSION                        = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 20.1
CL_DRIVER_VERSION                        = 20.1
CL_DEVICE_ADDRESS_BITS                   = 64
CL_DEVICE_AVAILABLE                      = true
CL_DEVICE_ENDIAN_LITTLE                  = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE          = 32768
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE      = 0
CL_DEVICE_GLOBAL_MEM_SIZE                = 403931233280
CL_DEVICE_IMAGE_SUPPORT                  = false
CL_DEVICE_LOCAL_MEM_SIZE                 = 16384
CL_DEVICE_MAX_CLOCK_FREQUENCY            = 1000
CL_DEVICE_MAX_COMPUTE_UNITS              = 1
CL_DEVICE_MAX_CONSTANT_ARGS              = 8
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE       = 100982808320
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS       = 3
CL_DEVICE_MEM_BASE_ADDR_ALIGN            = 8192
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE       = 1024
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR    = 4
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT   = 2
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT     = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG    = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT   = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE  = 0
Command queue out of order?              = true
Command queue profiling enabled?         = true
Using AOCX: hello_world.aocx
Context callback: Malformed program binary: missing .acl.board section
Context callback: kernel argument info is not available
Context callback: Invalid binary
ERROR: CL_INVALID_BINARY
Failed to create program with binary
AnilErinch_A_Intel
This could be related to the  Altera.icd file being used in the system.
Please see a thread below which discusses a similar issue.
https://community.intel.com/t5/Intel-High-Level-Design/Error-when-performing-emulation-for-v19-3/td-p/731970
Please let us know whether it helps.
Thanks and Regards
Anil
beiwang2003
Hi, Anil,
I've tried this by replacing the current Altera.icd file at /etc/OpenCL/vendors/ with the one at .../19.4/hld/Altera.icd. It is still the same error message during running:Context callback: Malformed program binary: missing .acl.board section
Bei
AnilErinch_A_Intel
It turns out that From version 19.4 onwards there are two options available
1. Legacy emulator
export CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA=1
./host -legacy-emulator
2. If you want to use the fast emulator
export CL_CONFIG_CPU_EMULATE_DEVICES=1
./host -emulator
Please try both the options and  let us know about the  performance.
Thanks and Regards
Anil
AnilErinch_A_Intel
Hi ,
Please let us know whether the below options
1. Legacy emulator
./host -emulator
Helped in resolving the issue
Thanks and Regards
Anil
AnilErinch_A_Intel
Hi ,
Please let us know whether the previous suggestion was helpful, and whether the issue was resolved.
Thanks and Regards
Anil
PVeli
Hello Anil,
When I am using legacy emulator for 19.3 I am getting following error. Please suggest me asap.
Platform: Intel(R) FPGA Emulation Platform for OpenCL(TM)
Using AOCX: traffic_stn.aocx
Context callback: clCreateProgramWithBinary failed
AnilErinch_A_Intel
Hi ,
for the latest error message which you are getting please refer the below forum link
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Got-CL-INVALID-BINARY-error-when-emulated-HelloWorld-example-on/td-p/34890
and let us know whether the suggestions outlined there helps to solve the issue.
Thanks and Regards
Anil
AnilErinch_A_Intel
Hi ,
Thanks and Regards
Anil
