Intel® High Level Design
gdb on FGPA DevCloud
Hongbo_R_Intel
I'm using the FPGA DevCloud, more specifically, the Arria 10 PAC Compilation and Programming with Development Stack 1.2.1.  I need debugging tools like gdb, but unfortunately, it does not seem that gdb is installed.
Could you install the debugging tools?
Thanks!
Hongbo
Hongbo_R_Intel
Don't bother.  I just found that there is a specialized gdb already installed on FPGA DevCloud. To use it:
source  /glob/development-tools/versions/intel-parallel-studio-2019/debugger_2019/bin/debuggervars.sh
/glob/development-tools/versions/intel-parallel-studio-2019/debugger_2019/gdb/intel64/bin/gdb-ia  ….
ChithraJ_Intel
Hi Hongbo,
As checking your query, we noticed that your issue is related to FPGA Devcloud. We have a dedicated forum to handle those specific issues in FPGA Devcloud, so we are moving this query to FPGA forum for a faster response.
Chithra
Hongbo_R_Intel
Thanks, Chithra! I am blocked by an issue due to the lacking of gdb on FPGA DevCloud. If someone can quickly install the toolset, that would be great.
Hongbo_R_Intel
