Intel® High Level Design
722 Discussions
OpenCL application hangs FPGA
RJimé1
Hello:
I am trying to run a multithreaded OpenCL + OpenMP (host side) application on Devcloud that targets FPGA. It worked fine around 2 weeks ago. However, it is now hanging after a call to clFlush that follows a call to clEnqueueWriteBuffer. Has anything changed in the Devcloud environment that explains this issue? Could you tell me how to address this?
RaeesaM_Intel
Thank you for posting in Intel Devcloud Forum.
Can you tell us whether you are using FPGA emulator or FPGA device.Also please share the job submission command.
We would be happy to help you out.
Raeesa
RJimé1
I'm launching it from interactive mode with:
qsub -I -l nodes=1:fpga_runtime:ppn=2 -d.
The application works well with the emulator. It only hangs with the FPGA device.
Thank you
RaeesaM_Intel
Since your issue is related to FPGA,we are moving this query to FPGA forum for a faster response.
Raeesa
AnilErinch_A_Intel
Hi ,
The BSP of the Dev cloud nodes gets updated to latest as and when it comes.
Please let us know whether you are facing the issue on the latest nodes and we can help you in debugging the issue,
Thanks and Regards
Anil
