Intel® High Level Design
722 Discussions
fpgaconf Error: No suitable slots found
Ziaul
The fpgaconf command is throwing a "No suitable slots found" error. The doc https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qs-ias-v1-2.pdf
says that, The interface-uuid should match the FIM version (PR interface ID), which matches in my case.
I tried the following two commands to match the IDs
fpgainfo fme = Pr Interface Id : 69528db6-eb31-577a-8c36-68f9faa081f6
packager gbs-info --gbs=hello_afu.gbs = "interface-uuid": "69528db6-eb31-577a-8c36-68f9faa081f6",
Although, the IDs match I am still getting the error.
Can you please help in this regard.
User ID - u48959
Node - c009
Ziaul
AthiraM_Intel
Since your issue is related to FPGA, we are moving this query to FPGA forum for a faster response.
Ziaul
It got resolved automatically.
