Intel® High Level Design
722 Discussions
OpenCL software emulation crashes when the Kernel uses more than 6MByte of memory
FPorr
the OpenCL software emulation crashes with a segmentation fault when the kernel utilizes more than 6MByte of memory. Example:
uchar arr[128*128*384]; // 6MByte -- Works uchar arr[128*128*385]; // more than 6MByte -- Segmentation Fault
If this behavior is intended, a warning message would be appreciated, to prevent people from searching for a non-existing bug in their code.
Setup:
Ubuntu 16.04.2
Intel FPGA SDK for OpenCL 18.0.0-219
Tested Boards:
Arria 10 (ref BSP and BSP of custom hardware)
Stratix 10 (only BSP of custom hardware)
KhaiChein_Y_Intel
May I request the testcase for replication? What is the cmd you are executing?
FPorr
thank you for the reply, I attached a simple test case to reproduce the error.
The build commands I used were:
# Host application make # Kernel aoc -march=emulator krnl.cl -o bin/krnl_emu.aocx
and for execution:
CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA=1 bin/host bin/krnl_emu.aocx
Depending on which size define is enabled in krnl.cl, the application either crashes or executes.
KhaiChein_Y_Intel
Hi, Thanks for the attachment. Please allow me some time to look into this. Thanks. (1507183204)
KhaiChein_Y_Intel
Hi, A lot has changed in the emulator since 18.0, not only in the old emulator flow (now called legacy emulator), but there is now a new emulator that replaces it in 19.1 (the fast emulator). Can you try this in 19.1 with the new fast emulator? Thanks,
KhaiChein_Y_Intel
Hi, May I know if you have any updates? Thanks
FPorr
I am sorry for the late response. I installed 19.1 but trying to compile any kernel using the fast emulator fails with:
Error: OpenCL kernel compilation FAILED
The ioc.log contains the following lines:
Using build options: -cl-std=CL1.2 -Xclang -Wuninitialized -I "/home/user/vector_add/device"
Failed to get platform id...: 0 (CL_SUCCESS)
Compilation failed!
Any thoughts on what might be the problem?
FPorr
I managed to solve the problem. It did not work because I forgot to install a device ... 😟
Anyway, using the fast emulator indeed removed the problem, the application no longer crashes for data > 6MB.
Thank you for your assistance.
