Intel® High Level Design
722 Discussions
POSEDGE and NEGEDGE counter or DUALEDGE counter
Karunakaran
HI,
   We are in need to counting both poedge and negedge. our master clock is 125mhz (8ns). we need to count every posedge (4ns) and negedge (4ns). in quartus SW both posedge and negedge is not working. we have tried to invert clk and give both as posedge, that is also not working. please suggest better way to use dual edge counter.
assign clk_n = ~clk;                                                         // used to check both posedge and negedge
always @(posedge clk or posedge clk_n) begin
N=ip_freq/(freq * multiple);                                          // counter value calc
if (rst) begin
counter <= 16'b0;
end
else begin
if(pulse_done)begin
F <= N;        // if pulse_done=1 then load counter
end
if (counter == F) begin
pulse_enb <=1'b1;                                                       // enable wave generation module
counter <= 16'b0;
pulse_done <= 1'b1;
end
else begin
pulse_done <= 1'b0;
counter <= counter + 1'b1;
pulse_enb <=1'b0;
end
end
end
RichardTanSY_Altera
Perhaps this article may help on your design.
http://www.ralf-hildebrandt.de/publication/pdf_dff/pde_dff.pdf
RichardTanSY_Altera
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Shyan Yew
