I want to give my idea abou cooling.
It is possible to make fans with intricate spiral shapes at the nano level using gold or other materials. Gold is often used in nanotechnology applications because of its unique properties, such as its high electrical conductivity, resistance to corrosion, and biocompatibility. But, using gold or other precious metals in the manufacture of such fans would likely be very expensive and may not be practical for most applications. Other materials, such as silicon or polymers, may be more suitable and cost-effective for creating fans at the nano level.
One of the way is that, Making fans with more spirals in the nano level could potentially increase the efficiency of the fans and improve their cooling performance.
Thank you for your suggestion, we will consider it. However, as you know, thermal design for devices is very complex and we need to take many factors into account. The optimal thermal design solution often varies under different environments and usage conditions.
Your idea does provide a new perspective for the cooling solution.
BR,
Matt
