Intel® High Level Design
722 Discussions
X2GO client connection failure: Socket Disconnected
agond2
Débutant
12 957 Visites
I am trying to open graphics port on DevCloud using X2GO clien and get socket disconnected error after starting the session
I have followed the steps from https://github.com/intel/FPGA-Devcloud/tree/master/main/Devcloud_Access_Instructions#61-opening-port-for-graphics-usage-in-x2go
Before launching the session I use the command
ssh -L 4002:s001-n<available node from 130-139>:22 devcloud
A minute after I launch the session, I get the error authentication failed-socket error :disconnected
Please find the attached images of the session properties and the error message.
0 Compliments
11 Réponses
MEIYAN_L_Intel
Employé
12 516 Visites
May I know do you have install the socat package as link: https://github.com/intel/FPGA-Devcloud/tree/master/main/Devcloud_Access_Instructions#61-opening-port-for-graphics-usage-in-x2go in chapter 4.1?
0 Compliments
agond2
Débutant
12 516 Visites
Yes, I have installed socat package in mobaxterm as mentioned in chapter 4.1. I still get socket disconnected error
0 Compliments
MEIYAN_L_Intel
Employé
12 516 Visites
I had download and install the X2GO with the setup provided in the guide.
I am able to replicate this issues and I am checking the information internally with the developer.
I will reply here once I had the reply from the developer.
0 Compliments
Lawrence_L_Intel
Employé
12 516 Visites
I tested on my side.
Steps:
  1. login to headnode from mobaxterm: ssh colfax-intel
  2. Use devcloud_login script and connect to s001-n138 (use selection option 4). Note the copy and paste note:
  3. Open a new mobaxterm and paste:
4. Startup X2Go with following option in preferences
In about one minute my X2Go comes up.
Let me know if this works.
0 Compliments
Lawrence_L_Intel
Employé
12 516 Visites
I see my image copy and paste above didn't work - please confirm you are using login script under: /data/intel_fpga/devcloudLoginToolSetup.sh
0 Compliments
Lawrence_L_Intel
Employé
12 516 Visites
Can you show me the exact command you are using to open the port using the ssh command? First you need to open the port on your PC (not on the headnode) through Mobaxterm. For instance ssh -L 4002:s005-n006:22 colfax-intel
opens the port on node graphics port for s005-n006. Please show the exact command you are running on the PC from Mobxaterm. Also note you first need to be logged into the compute node before executing this command. Cheers Larry
0 Compliments
agond2
Débutant
12 516 Visites
Hi Larry,
Apologies for the delay in my response. I was able to open graphics port and launch quartus on n137.
What I missed earlier was logging in the the node before opening the port.
In short this is what I did:
ssh devcloud
devcloud_login (select 137)
ssh -L4002:s001-n137:22 devcloud
Only at this point launch the X2GO session
from the command prompt of GUI,
tools_setup (select appropriate version)
launch quartus using
quartus &
Thanks a lot for your help.
-Sincerely,
Atharva
0 Compliments
MEIYAN_L_Intel
Employé
12 516 Visites
May I know any update?
0 Compliments
agond2
Débutant
12 516 Visites
Hi, Confirming that this issue is now resolved. You may close the topic.
-Atharva
0 Compliments
MEIYAN_L_Intel
Employé
12 516 Visites
Thank you for your update.
0 Compliments
HongboRong
Débutant
8 428 Visites
Hello, I encounter a similar issue. Here are the steps:
  • On login-2 node: devcloud_login
          Choose 1) Arria 10 PAC Compilation and Programming - RTL AFU, OpenCL  and 1) 1.2.1
  • In a new mobaxterm:  ssh -L 4002:s005-n003:22 colfax-intel
  • Start an X2GO session, and I got such an error:
Any idea?
Thanks!
Hongbo
0 Compliments
Répondre
