Intel® High Level Design
722 Discussions
high part of mm_host address are x state in quartus simulation.
chalie_Robert
I build a HLS project and verify the correctness via simulation in HLS project. I use one mm_host interface in my component interface.I find the address change correctly in HLS project.
my component is here with hls_always_run_component enabled
 I build a quartus project and add this IP into the project,run IP Geneartion command and generate simulator setup script for IP command, I source and genrated tcl script, there are no errors  in above steps.
I find the high part of my mm_host address are in x state while read enable is valid.
I don't know where are the problems. Can anyone help me,Thanks.
My component is in attached.
Any example project with right addresses in HLS and quartus simulation is also apprecated.
aikeu
aikeu
Hi chalie_Robert,
I will close the thread if no further question.
Aik Eu
aikeu
Hi chalie_Robert,
I am closing the thread for now as we do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Aik Eu
