- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Public statements imply no special alignment requirements for AVX, and that there will be no particular support for more than the 16-byte alignments supported in 64-bit OS. However, the vmovaps instruction requires 32-byte alignment, even though documents indicate there may be no significant advantage in using it. To avoid breaking applications where VECTOR ALIGNED directives/pragmas are used with Intel compilers, those directives would have to continue to require only 16-byte alignment.
Link copiado
1 Responder
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Tim18,
You are correct, 16-byte alignment is all that can be guaranteed in some contexts, although going forwardcompilers are encouraged to support 32-bit alignments where possible. There are significant performance advantages to being 32-byte aligned if you have 32-byte loads and stores, even for instructions that do not require alignment to behave correctly.
I won't advise anyone to use VMOVDQA ymm flavors - they #GP if not aligned: I have been burned too many times by this in production code. You may want to use them for checking alignment as a debug tool, but in shipping code it would be much safer to use VMOVDQU (or fused load/op) loads and stores.
Mark
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
