Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1138 Discussions
Will a vector version of rol be supported in the future
fafcv_z_
Hi
I am trying to vectorise code that is using mainly integer instructions (add,rol,xor). I cannot get the compiler to vectorise this.
My understanding is there is no vector version of rol. Will this be supported in the future?
I have tried on Westmere, Sandy Bridge and Haswell with both SSE and AVX. In AVX the rol is repalced by shld, but there is no gain.
I seem to be able to get the code to unroll, but no vector instructions are inserted (according to disassembler). There is a slight speedup (~10%), but I believe this is due to better use of multiple ALUs; from more independent instructions.
Any guidance would be welcome.
Note; Using  intel16.0 icc - linux - SB/HSW
jimdempseyatthecove
What size integer? Signed or unsigned? Placement? Flow after rol? Anything other that may be pertinent?
Can you show your code, including representative numbers for loops, array size etc... A complete working (dummied up) example would be good.
Jim Dempsey
