Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1151 Discussions
looking for information sources on code optimization using the Intel CPU and the MMX/SSE family instruction set
amoshkov
Im looking for information sources on code optimization using the Intel CPU and the MMX/SSE family instruction set.
From what I have searched this group is the closest group to the subject of code optimization / vectorization.
Could someone recommend of:
  1. A good reference book?
  2. A relevant user group (within Intel Software Network or any external user group)
Avner
TimP
Undoubtedly, vectorization will be crucial to the application of AVX. Your topic is still too broad. You may be interested in compiler auto-vectorization with Fortran (vast on-line resources available) or C (similar, with more requirements, some resources available), or something else. For example, the topic has been discussed frequently on the Intel compiler forum sites.
amoshkov
Im interested in optimization for C++ code. I am using the Intel 64 and IA-32 Architectures Software Developer's Manuals (5 volumes) for reference.
What I am looking for is a user group where I can post general SSE programming questions and see example source code. For example I want to know if there is a conditional statement equivalent to if/else in SSE, where I could condition intrinsic operations based on results in the registers.
Avner
TimP
SSE4 blend instructions implement if/else conditional moves, such as Fortran MERGE. Prior to SSE4, the same operation could be implemented with masks.
srimks
New Contributor II
Quoting - amoshkov
I would suggest reading first following - "IA-32 Intel Architecture Optimization Manual", followed by - "Intel Intrinsic Functions Reference" & "Intel C++ Compiler Reference". Regarding book I would suggest - "The Software Vectorization Handbook - Aart J.C.Bik" & "Optimizing Compilers Modern Architecture - Randy Allen & Ken Kennedy". -> HIH
