Difference in output of Intel Integrated performance primitives (IPP) fir and convolution functions
Faheem_S_
ビギナー
1,010件の閲覧回数
While working with Intel IPP 7.1 (composer XE 2013) I noticed difference in tail end of output samples between IPP 'fir' and 'convolution' calls. So in the calls below
status = ippsFIR_Direct_64f(pSrc, pDst_f, N+M-1, pTaps,M, pDlyLine,&pDlyLineIndex); status = ippsConv_64f(pSrc, N, pTaps, M, pDst);
with M=7, N=11 and pDlyLine initialized to all zeros, everything else being same:
pDst_f and p_Dst differ in last three indices i.e pDst_f!=pDst for k=14,15,16
I expected them to be exactly equal with third parameter (number of iterations)=N+M-1 in the fir call. Test file is attached. Any ideas?
Thanks in advance!
Faheem
0 件の賞賛
7 返答(返信)
SergeyKostrov
高評価コントリビューター II
1,010件の閲覧回数
>>... Test file is attached. Any ideas? Thank you for the test-case! I wish everybody does the same to save time for investigation... Best regards, Sergey
SergeyKostrov
高評価コントリビューター II
1,010件の閲覧回数
Hi everybody, I'd like to share results of my investigation. There is some issue ( actually very old! ) related to a 'numIters' parameter of 'ippsFIR_Direct_32f' or ippsFIR_Direct_64f, etc, functions. In the 'ipps.h' header file there is a comment: ... // numIters number of samples in the input array ... However, in the documentation there is some additional note ( I marked it with *** ): ... The function ippsFIR_Direct is declared in the ipps.h file. This function filters an input array pSrc or pSrcDst containing numIters samples through a single-rate filter, *** and stores the resulting numIters samples in pDst *** or pSrcDst, respectively... ...
SergeyKostrov
高評価コントリビューター II
1,010件の閲覧回数
>>...Taps Position: nn >>... Regarding 'Taps Position' please look at source codes of a new test-case.
SergeyKostrov
高評価コントリビューター II
1,010件の閲覧回数
I've done a set of tests and here results: // Test #0 - No Errors Taps Position: 0 Calling IPP [ ippsConv_32f ] function Succesful: Status = 0 Calling IPP [ ippsFIR_Direct_32f ] function Succesful: Status = 0 Displaying Convolution and FIR results: Index 0 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 1 [ CONV = 1.000000 FIR = 1.000000 ] DIFF = 0.000000000000000000000000 Index 2 [ CONV = 2.000000 FIR = 2.000000 ] DIFF = 0.000000000000000000000000 Index 3 [ CONV = 3.000000 FIR = 3.000000 ] DIFF = 0.000000000000000000000000 Index 4 [ CONV = 4.000000 FIR = 4.000000 ] DIFF = 0.000000000000000000000000 Index 5 [ CONV = 5.000000 FIR = 5.000000 ] DIFF = 0.000000000000000000000000 Index 6 [ CONV = 6.000000 FIR = 6.000000 ] DIFF = 0.000000000000000000000000 Index 7 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 8 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 9 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 10 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 11 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 12 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 13 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 14 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 15 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 16 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Comparison of Convolution and FIR results: // Test #1 - No Errors Taps Position: 1 Calling IPP [ ippsConv_32f ] function Succesful: Status = 0 Calling IPP [ ippsFIR_Direct_32f ] function Succesful: Status = 0 Displaying Convolution and FIR results: Index 0 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 1 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 2 [ CONV = 1.000000 FIR = 1.000000 ] DIFF = 0.000000000000000000000000 Index 3 [ CONV = 2.000000 FIR = 2.000000 ] DIFF = 0.000000000000000000000000 Index 4 [ CONV = 3.000000 FIR = 3.000000 ] DIFF = 0.000000000000000000000000 Index 5 [ CONV = 4.000000 FIR = 4.000000 ] DIFF = 0.000000000000000000000000 Index 6 [ CONV = 5.000000 FIR = 5.000000 ] DIFF = 0.000000000000000000000000 Index 7 [ CONV = 6.000000 FIR = 6.000000 ] DIFF = 0.000000000000000000000000 Index 8 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 9 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 10 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 11 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 12 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 13 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 14 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 15 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 16 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Comparison of Convolution and FIR results: // Test #2 - No Errors Taps Position: 2 Calling IPP [ ippsConv_32f ] function Succesful: Status = 0 Calling IPP [ ippsFIR_Direct_32f ] function Succesful: Status = 0 Displaying Convolution and FIR results: Index 0 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 1 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 2 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 3 [ CONV = 1.000000 FIR = 1.000000 ] DIFF = 0.000000000000000000000000 Index 4 [ CONV = 2.000000 FIR = 2.000000 ] DIFF = 0.000000000000000000000000 Index 5 [ CONV = 3.000000 FIR = 3.000000 ] DIFF = 0.000000000000000000000000 Index 6 [ CONV = 4.000000 FIR = 4.000000 ] DIFF = 0.000000000000000000000000 Index 7 [ CONV = 5.000000 FIR = 5.000000 ] DIFF = 0.000000000000000000000000 Index 8 [ CONV = 6.000000 FIR = 6.000000 ] DIFF = 0.000000000000000000000000 Index 9 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 10 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 11 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 12 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 13 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 14 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 15 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 16 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Comparison of Convolution and FIR results: // Test #3 - No Errors Taps Position: 3 Calling IPP [ ippsConv_32f ] function Succesful: Status = 0 Calling IPP [ ippsFIR_Direct_32f ] function Succesful: Status = 0 Displaying Convolution and FIR results: Index 0 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 1 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 2 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 3 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 4 [ CONV = 1.000000 FIR = 1.000000 ] DIFF = 0.000000000000000000000000 Index 5 [ CONV = 2.000000 FIR = 2.000000 ] DIFF = 0.000000000000000000000000 Index 6 [ CONV = 3.000000 FIR = 3.000000 ] DIFF = 0.000000000000000000000000 Index 7 [ CONV = 4.000000 FIR = 4.000000 ] DIFF = 0.000000000000000000000000 Index 8 [ CONV = 5.000000 FIR = 5.000000 ] DIFF = 0.000000000000000000000000 Index 9 [ CONV = 6.000000 FIR = 6.000000 ] DIFF = 0.000000000000000000000000 Index 10 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 11 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 12 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 13 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 14 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 15 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 16 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Comparison of Convolution and FIR results: ... // An so on until 'numIters' < than 11 ( M in your case ) ... // Test #9 - No Errors Taps Position: 9 Calling IPP [ ippsConv_32f ] function Succesful: Status = 0 Calling IPP [ ippsFIR_Direct_32f ] function Succesful: Status = 0 Displaying Convolution and FIR results: Index 0 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 1 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 2 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 3 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 4 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 5 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 6 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 7 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 8 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 9 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 10 [ CONV = 1.000000 FIR = 1.000000 ] DIFF = 0.000000000000000000000000 Index 11 [ CONV = 2.000000 FIR = 2.000000 ] DIFF = 0.000000000000000000000000 Index 12 [ CONV = 3.000000 FIR = 3.000000 ] DIFF = 0.000000000000000000000000 Index 13 [ CONV = 4.000000 FIR = 4.000000 ] DIFF = 0.000000000000000000000000 Index 14 [ CONV = 5.000000 FIR = 5.000000 ] DIFF = 0.000000000000000000000000 Index 15 [ CONV = 6.000000 FIR = 6.000000 ] DIFF = 0.000000000000000000000000 Index 16 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Comparison of Convolution and FIR results: // Test #10 - No Errors Taps Position: 10 Calling IPP [ ippsConv_32f ] function Succesful: Status = 0 Calling IPP [ ippsFIR_Direct_32f ] function Succesful: Status = 0 Displaying Convolution and FIR results: Index 0 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 1 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 2 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 3 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 4 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 5 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 6 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 7 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 8 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 9 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 10 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 11 [ CONV = 1.000000 FIR = 1.000000 ] DIFF = 0.000000000000000000000000 Index 12 [ CONV = 2.000000 FIR = 2.000000 ] DIFF = 0.000000000000000000000000 Index 13 [ CONV = 3.000000 FIR = 3.000000 ] DIFF = 0.000000000000000000000000 Index 14 [ CONV = 4.000000 FIR = 4.000000 ] DIFF = 0.000000000000000000000000 Index 15 [ CONV = 5.000000 FIR = 5.000000 ] DIFF = 0.000000000000000000000000 Index 16 [ CONV = 6.000000 FIR = 6.000000 ] DIFF = 0.000000000000000000000000 Comparison of Convolution and FIR results: // Test #11 - Not Calculated and Application Crashes Taps Position: 11 Calling IPP [ ippsConv_32f ] function Succesful: Status = 0 Calling IPP [ ippsFIR_Direct_32f ] function Succesful: Status = 0 Displaying Convolution and FIR results: Index 0 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 1 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 2 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 3 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 4 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 5 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 6 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 7 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 8 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 9 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 10 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 11 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 12 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 13 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 14 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 15 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Index 16 [ CONV = 0.000000 FIR = 0.000000 ] DIFF = 0.000000000000000000000000 Comparison of Convolution and FIR results: Note for the Test #11: In Debug configuration a message box with an error will be displayed: Debug Error! ... Run-Time Check Failure: Stack around the variable 'pDstF' was corrupted ...
SergeyKostrov
高評価コントリビューター II
1,010件の閲覧回数
Summary: - There is some issue with 'numIters' ( number of samples in the input array ) parameter ( I think Intel IPP Software Engineers should explain why it works so ) - Source codes of your modified test-case attached - I tested 'ippsConv_32f' and 'ippsFIR_Direct_32f' IPP functions only ( the Single-Precision Floating-Point type ) - Verification of results based on '!=' is commented out and a new one is based on 'If a difference between CONV-FIR values is greater than an Eplsilon' Best regards, Sergey
Faheem_S_
ビギナー
1,010件の閲覧回数
Dear Sergey Thanks a lot for looking into the issue and confirming the problem. Your help is much appreciated. May be Intel can address the issue in next release of IPP. Thanks again! Regards Faheem
SergeyKostrov
高評価コントリビューター II
1,010件の閲覧回数
>>...May be Intel can address the issue in next release of IPP. That would be nice. I'm simply interested to get more details: Are you going to use 'ippsConv_xxf' or 'ippsFIR_Direct_xxf' in your real application?
返信
