Hi Sergey , www, q, thanks for raising the issue here. Before we investigate it, i noticed there are some problems about the code, 1) if use statc link, the call ippInit() is needed before call all IPP functions, please see http://software.intel.com/en-us/articles/ipp-dispatcher-control-functions-ippinit-functions 2) Regarding the OpenMP threads and IPP internal threading. Some discussion are in http://software.intel.com/en-us/articles/openmp-and-the-intel-ipp-library . Don't recommend to use nested IPP and OpenMP threads. also disable HT etc. 3) functions call overheads, yes, it is possible, a serial of IPP function calls have overhead and the serial operations increase the times of memory write-in and write out . As a result , memory latences may eat the benefit of faster computing. In order to simplify the performance comparng, as sergey suggested, how about try serial code both loops and IPP serial library. Please let us know after chang ippInit() and OpeMP set, what is the result of first post? Best Regards, Ying
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
