How can I use DV codecs with umc_video_enc_con?
shyaki
Hi, all
I'd like to test the DV codecs using umc_video_enc_con. Can you tell me which codec option I should put? Thanks.
shyaki
Please give me some hints about how to use the DV codecs in the IPP lib. Is there any sample code? Thank you very much for your help.
Vladimir_Dudnik
we do not support DV encoder in IPP 5.2 beta sample, as you can see in video_enc_con readme.htm
Options:
[m2|m4|h264|h263|h261] - encoder type, could be: h264 for h264 encoder, h263 for h263 encoder, h261 for h261 encoder, m2 for mpeg2, m4 for mpeg4
So you might want to study UMC manual and write simple application to test DV encoder by yourself or you can wait for IPP 5.2 final release which is coming soon, where we will add such support to video_enc_con application.
Vladimir
