6814 Discussions
Latest IPP fails to properly load 411 JPEG when DCT scaling is applied
johnt
Hi there,
The latest IPP code fails to properly load the following JPEG when using a DCT scaling like JD_1_4:
ftp://ftp.jriver.com/pub/downloads/music/tmp/ipp_fail_2.jpg
It seems like it's a problem with 411 JPEGs, as the same JPEG with 211 encoding doesn't show the problem.
I think something is wrong with the fourth h-sample when calling ppiDCTQuantInv8x8To2x2LS_JPEG_16s8u_C1R inside ReconstructMCURowBL8x8To2x2, but I'm not certain what.
Thanks for any help.
johnt
Bump.
Is Intel IPP still supported by Intel? Is there some other avenue we should pursue for bugs?
This thread also has an open IPP bug we need help with (we got great help from Vladimir Dudnikin that thread to begin with, but that was some time ago):
http://software.intel.com/en-us/forums//topic/57398
Vladimir_Dudnik
Sure, Intel IPP is supported by our development and technical support teams. You can submit your issue reports directly to Intel Premier Support where they will fall to our data base and will be tracked on regular base.
I'm sorry for the delay, our JPEG expert was on vacation. Now we are investigating your issue report and I'll update your with status of this soon. Thank you for your interest to Intel Integrated Performance Primitives product.
Vladimir
johnt
Thanks Valdimir.
We'll eagerly await a fix for either (or both) of the open JPEG issues we're having.
Best,
John
Vladimir_Dudnik
Hi John,
I've cretated issue report for you on Intel Premier Support, so you will be notified when we find the reason and solution for that issue.
Vladimir
johnt
It looks like the code delivered in this thread also fixes this issue:
http://software.intel.com/en-us/forums/showthread.php?t=57398#54608
Thanks!
Vladimir_Dudnik
I'll check with our engineer, I thought his second fix was not integrated yet. Good if he did both at one drop.
Vladimir
Vladimir_Dudnik
I've check with our engineer, he confiremd that both fixes were integrated into that drop.
Vladimir
