Hi All,
I installed latest IPP product and I have video processing code in OpenCV. I recompiled OpenCV with flag WITH_IPP however I don't see any performance improvement. What I'm missing ? How can I tell OpenCV is detecting the IPP ?
Now after make finish I'm getting error:
You need to apply this patch: https://github.com/opencv/opencv/pull/8109/files
- « Previous
- 1
- 2
- Next »
[EITANS] "there is no guaranty" .... is that a general statement or only when using ICV ?
In general, not every OpenCV function is optimized with IPP, so performance benefit from IPP depends on functionality you are using.
[EITANS] Can you elaborate how to use it and what does it tells me ?
This function can switch IPP optimizations on and off for any following OpenCV function. By default every available optimizations is enabled. By the way if you built OpenCV with OpenCL support many IPP optimizations could be overshadowed by OpenCL code, since it has higher priority in most cases.
You can measure IPP performance using this template:
// Turn off all optimizations except IPP cv::setUseOptimized(false); cv::ipp::setUseIPP(true); timer_start cv::resize(...) timer_end // Turn on all optimizations except IPP cv::setUseOptimized(true); cv::ipp::setUseIPP(false); timer_start cv::resize(...) timer_end
The patch worked. Great.
You wrote: ... You can check performance difference by using cv::ipp::setUseIPP(bool) function before OpenCV calls.
I see update about how to use setUseIPP. Thanks. Will try it out first.
@Pavel, I see the method cv2.setUseOptimized(False) however I can't find 'ipp' over the CV2 python module. Thoughts ?
It seems that these functions are not declared for export to python. I submitted another patch: https://github.com/opencv/opencv/pull/8114/files
Thanks!
- « Previous
- 1
- 2
- Next »
