Hi all
I am using AEC of IPP 4.1.
For a perfect AEC which params can i use?
For FRAME_SAMPLES, NUM_SEGMENTS,PSD_ADAPT_WEIGHT
Thank for your instruction
this sample was updated in IPP v5.0 beta, so could you please to try new version?
Vladimir
Thank for your reply.
But actually, do you want to say that? we will use new lib with the sample example? or we will test with new lib and new example.
I only found one sample codeof AEC of intel which it's not included in the setup package of lib IPP. Do it have a new version of this sample code?
Can you make an more detail instruction?
I meant we have updated version of this sample in IPP v5.0 beta. It has several issues solved and also other small improvements. Unfortunately, IPP v5.0 beta program was closed, so you can't download samples (if you did not registered for beta program before closure date). Let wait until IPP v5.0 final release (near end of this year)
Vladimir
Topic Options
