6832 Discussions
efficient way to compute xe^(-x^2/a) and x / (1 + x^2/a) for IPP
Edwin_Z_
          I am wondering if IPP 8.0 has any way to efficiently implement the xe(-x^2/a), where a is a positive float number (ipp32f), where x is an array (potential large array) of data type ipp32f. I have used IPP 8.0 to element-wise product of x and e(-x^2/a), where i have used additional function call to compute the power component of the exponent (i.e., -x^2/a ). Due to multiple function calls, the evaluation of the above function becomes the bottleneck. Similar arguments applies to the x / (1 + x^2/a) as well. Is there any function calls respectively that I can directly compute the above two formula?
Best Regards
Edwin
Chao_Y_Intel
Edwin,
You can have several function combined to compute the value. For example,
For example, for this function x / (1 + x^2/a) computation, you can use the following function:
x^2:  ippsMul_(x,x, y1, ....)
x^2/a:  ippsippsDivC(y1,a,y2,...)
(1 + x^2/a):  ippsAddC(y2, 1, y3,...)
x/(1 + x^2/a):  ippsDiv(x,y3, y4.....)
Chao
Edwin_Z_
             I have implemented in this way, is there any way to improve?
ipp32f* x; //this is an array with 1 million elements
ipp32f* x_buffer; //this is a working buffer to store some results, it has the same length of x
ipp32f* x_result; //this is to store the final result
ipp32f  kappa; //this is the sqrt of a in the above formular
int destLength; // this is the number of element in the array x
//this is to implement the xe(-x^2/a)
m_status = ippsDivC_32f( x, kappa, x_buffer, destLength );
m_status = ippsSqr_32f_I( x_buffer, destLength );
m_status = ippsMulC_32f_I( -1.0, x_buffer, destLength );
m_status = ippsExp_32f_I( x_buffer, destLength );
m_status = ippsMul_32f( x_buffer, x, x_result, destLength );
//this is to implement x/(1 + x^2/a)
m_status = ippsAddC_32f_I( 1.0, x_buffer, destLength );
m_status = ippsDiv_32f_I( x_buffer, x, destLength );
Edwin_Z_
    Is there any function to compute exp( -x^2 ) directly (i.e., Gaussian function)? If the ipp has the function to compute this directly, then the rest would be fast.
Best Regards
Edwin
Igor_A_Intel
Hi Edwin,
there is no "direct" Gaussian function in IPP. In order to improve your pipeline I would like to suggest you (taking into account your word "large" in the first post) to perform your processing by small pieces of data - that the total length of all your vectors is less than your CPU L0 cache size. And then add one more loop above (from the one piece length to the total vector length). In this case, as load and store are "for free" if are inside L0, you'll have the same performance as if all arithmetic is done in one single function. If you use Intel SVML library for this purpose, you can achieve additional speedup in comparison with IPP as SVML doesn't perform parameters check and can be used with Intel compiler as a native set of intrinsics. (SVML is a part of Intel compiler run-time libraries).
regards, Igor
Edwin_Z_
Hi, Igor:
      From the manual, i can find the RandGauss, which is essentially compute the exp( -x^2 ) with mean = 0, std = 1 and some random variable x. By comparison, in my case, the x is given instead of randomly generate. So i guess there should be some implementation on method.
Best Regards
Edwin
Edwin_Z_
    By the way, is there any one know the name xe^(-x^2)? i plot it in Matlab and looks like an impluse function.xe_x2.jpg
b_k_
For xe(-x^2/a) , use (-1/a) and reuse buffers:
m_status = ippsSqr_32f( x, x_result, destLength );
m_status = ippsMulC_32f(x_result, -(1.0/a), x_result, destLength ); // constant and reuse of x_result
m_status = ippsExp_32f( x_result, x_result, destLength );
m_status = ippsMul_32f( x, x_result, x_result, destLength );
Hopefuly the constant term (-1/a) is accurate enough.
OpenMP can be used to run the code in parallel, but only if the x vector is large enough to justify the overhead.
If x can be minimized to integer (16 or better 8) a lookup might be useful?
