how can I get IPP 4.0
hongling_meng
I have download IPP 5.0,but there is something wrong when I compiled for my pxa 255 platform.I'd like to test IPP 4.0 for pxa 255,but I can't find it in IPP website.How can I get it?Thank you.
Vladimir_Dudnik
Hello, the latest available IPP version is 5.1. We do not keep previous versions available.
Vladimir
mapblast
I had something of a similar question as I found a post (by vdudnik) mentioning that you can go to premier.intel.com to download the earlier versions. But when I register and then login to premier it ends up on a "Page Not Found" page. No help.
But maybe I don't need an earlier version?
I'm trying to find information regarding IPP for use on our product. The device runs CE 4.2 using Xscale PXA255 hardware.
We would like to add MP3 encoding and decoding. Does the current version of IPP support this platform and what are the system requirements (CPU, clock, memory) required to get real-time MP3 encoding?
The hardware is already built, being sold, and in the field so changing it is not an option. But if we can add IPP to expand the capabilities that would be a wonderful thing and would also help us in choosing processor/platforms for the next product.
Thank you.
-Jerry
Vladimir_Dudnik
Hi Jerry,
you can get IPP for IXP, which should run on PXA255 processors because they are compatible with IXP42x processor family.Having IPP for IXP you can evaluate IPP media sample, which provide you set of codecs, including MP3 audio encoder and .
Vladimir
Vladimir_Dudnik
Hi Jerry,
you can get IPP for IXP, which should run on PXA255 processors because they are compatible with IXP42x processor family.Having IPP for IXP you can evaluate IPP media sample, which provide you set of codecs, including MP3 audio encoder and can be .
Vladimir
Vladimir_Dudnik
Hi Jerry,
you can get IPP for IXP, which should run on PXA255 processors because they are compatible with IXP42x processor family.Having IPP for IXP you can evaluate IPP media sample, which provide you set of codecs, including MP3 audio encoder and can be built on both Linux and Windows CE.
Vladimir
Arul_J_
I would like to know
1) what are the issues Fixed in 5.0 releases
2) what are all the known issue in IPP 5.0 release
3) what are the issues Fixed in 4.0 releases
4) what are all the known issue in IPP 4.0 release
Please advice me how to get the above
Arul
