Hi all,
I found the next pseudocode for ippiRGBToHSV_8u_C3R in IPP documentation
The conversion algorithm from RGB to HSV can be represented in pseudocode as follows:
// Value: V = max(R,G,B); // Saturation: temp = min(R,G,B); if V = 0 then // achromatics case S = 0//
H = 0 else // chromatics case S = (V - temp)/V // Hue: Cr = (V - R) / (V - temp) Cg = (V -
G) / (V - temp) Cb = (V - B) / (V - temp) if R = V then H = Cb - Cg if G = V then H = 2 + Cr - Cb if B = V
then H = 4 + Cg - Cr H = 60*H if H < 0 then H = H + 360
The computed H,S,V values are scaled to the full range of the destination data type
I realized this pseudocode in small console application
int GetHSV(int nR,int nG, int nB,int* pnH, int* pnS, int* pnV)
int nH,nS,nV;
int nCr,nCg,nCb;
int nResult=0;
int nTemp=0;
nV=nR;
if(nG>nV) nV=nG;
if(nB>nV) nV=nB;
nTemp=nR;
if(nG<nTemp) nTemp=nG;
if(nB<nTemp) nTemp=nB;
if(nV==0)
nH=0;
nS=0;
else
nS = (nV - nTemp);
nCr=(nV-nR)/(nV-nTemp);
nCg=(nV-nG)/(nV-nTemp);
nCb=(nV-nB)/(nV-nTemp);
if(nR==nV) nH=nCb-nCg;
if(nG==nV) nH=2+nCr-nCb;
if(nB==nV) nH=4+nCg-nCr;
nH=nH*60;
if(nH<0) nH=nH+360;
*pnH=(int)(nH*0.71);
*pnS=nS;
*pnV=nV;
return nResult;
I also made a small console application, that uses ippiRGBToHSV_8u_C3R for color conversion.
The results are very strange. When we have simple colors like red, green, cyan, magenta, everything is fine, the results of two console applications are the same.
But when I try something else (for example RGB(198,97,27)), results are different.
Is my relization of pseudocode correct? If it's correct where can I get the real pseudocode of ippiRGBToHSV_8u_C3R?
Roman
See right code below(int vs float):
int GetHSV_32f(int nR, int nG, int nB, int* pnH, int* pnS, int* pnV)
float nH, nS, nV;
float nCr, nCg, nCb;
float nResult = 0;
float nTemp = 0;
nV = nR;
if (nG>nV) nV = nG;
if (nB>nV) nV = nB;
nTemp = nR;
if (nG<nTemp) nTemp = nG;
if (nB<nTemp) nTemp = nB;
if (nV == 0)
nH = 0;
nS = 0;
}else{
nS = (nV - nTemp)/nV;
nCr = (nV - nR) / (nV - nTemp);
nCg = (nV - nG) / (nV - nTemp);
nCb = (nV - nB) / (nV - nTemp);
if (nR == nV) nH = nCb - nCg;
if (nG == nV) nH = 2 + nCr - nCb;
if (nB == nV) nH = 4 + nCg - nCr;
nH = nH * 60;
if (nH<0) nH = nH + 360;
*pnH = (int)(nH*0.71);
*pnS = nS*255.f;
*pnV = nV;
return nResult;
float nH, nS, nV;
float nResult = 0;
float nTemp = 0;
nV = nR;
if (nG>nV) nV = nG;
if (nB>nV) nV = nB;
nTemp = nR;
if (nV == 0)
nH = 0;
nS = 0;
}else{
nH = nH * 60;
*pnS = nS*255.f;
*pnV = nV;
return nResult;
Hi Sergey,
Thank you very much for a fast reply!
Roman
![](/skins/images/BC9A7A3465121B56B278007F4EE8899F/responsive_peak/images/icon_anonymous_message.png)
