Intel® MPI Library
2 nodes on Windows 7 x64 assistance
jimdempseyatthecove
Installed Parallel Studio XE 2016 Update 2 Cluster edition on Windows 7 Pro x64 (installed on two systems) and attempting to run the MPI test program.
Each system can run the test program on itself, but I cannot run on other system from either system.
hydra_service.exe can be -remove and -install correctly.
I can see and copy files from each system to the other system (to shared folder), test program installed in shared folder.
C:\Test\TestMPI_CPP\TestMPI_CPP>mpiexec.exe -n 8 -hosts thor \Downloads\testmpi_cpp.exe
Hello world: rank 0 of 8 running on Thor
Hello world: rank 1 of 8 running on Thor
Hello world: rank 2 of 8 running on Thor
Hello world: rank 3 of 8 running on Thor
Hello world: rank 4 of 8 running on Thor
Hello world: rank 5 of 8 running on Thor
Hello world: rank 6 of 8 running on Thor
Hello world: rank 7 of 8 running on Thor
C:\Test\TestMPI_CPP\TestMPI_CPP>mpiexec.exe -n 8 -hosts i72600k \Downloads\testmpi_cpp.exe
Error connecting to the Service
[mpiexec@Thor] ..\hydra\utils\sock\sock.c (270): unable to connect from "Thor" to "i72600k" (No error)
C:\Test\TestMPI_CPP\TestMPI_CPP>dir \\i72600k\Downloads\TestMPI_CPP.exe /b
TestMPI_CPP.exe
The results above are same (with name changes) when run on other host.
I've run mpiexec -register on both systems.
Any hints would be helpful
Jim Dempsey
James_T_Intel
Do you have any firewalls between the two systems?  Can each ping the other by name?
jimdempseyatthecove
Yes. Both can ping each other by name.
This would have been self-evident by DIR \\name\folder working.
Windows Firewall on both systems have checks on
Intel(R) MPI Library Process Manager, Intel
Anything else need to be enabled? (added)
Jim Dempsey
James_T_Intel
You will probably need to set an exception for the program you are trying to run as well.  See https://software.intel.com/en-us/articles/firewalls-and-mpi for general steps for working with a firewall.
jimdempseyatthecove
James,
After a bit of work, I had to add a Firewall exception to allow port 8679 incoming TCP packets.
At least the sample test program now runs.
Jim Dempsey
jimdempseyatthecove
Well this is interesting
While on system A I can mpiexec run on system A or B
and
While on system B I can mpiexec run on system B or A
From either, I cannot run on both
The documentation gives conflicting information as to the command line for multiple hosts.
Can you provide a correct command line? (run Foo.exe on systems A and B)
Jim Dempsey
James_T_Intel
There are several different ways to do that.  Here are a few examples, see https://software.intel.com/en-us/articles/controlling-process-placement-with-the-intel-mpi-library for more.  The article is aimed at Linux*, simply substitute mpiexec.hydra for mpirun to run in Windows*.
>mpiexec.hydra -n 2 -ppn 1 -hosts sysA,sysB Foo.exe
>type hosts.txt
sysA
sysB
>mpiexec.hydra -n 2 -ppn 1 -f hosts.txt Foo.exe
>type machines.txt
sysA:1
sysB:1
>mpiexec.hydra -n 2 -machinefile machines.txt Foo.exe
jimdempseyatthecove
The examples shows using mpiexec, not mpiexec.hydra.
My results:
C:\Program Files (x86)\IntelSWTools>mpiexec.hydra -n 16 -ppn 8 -hosts Thor,i72600k \Downloads\TestMPI_CPP.exe
Hello world: rank 0 of 16 running on Thor
Hello world: rank 1 of 16 running on Thor
Hello world: rank 2 of 16 running on Thor
Hello world: rank 3 of 16 running on Thor
Hello world: rank 4 of 16 running on Thor
Hello world: rank 5 of 16 running on Thor
Hello world: rank 6 of 16 running on Thor
Hello world: rank 7 of 16 running on Thor
Hello world: rank 8 of 16 running on i72600K
Hello world: rank 9 of 16 running on i72600K
Hello world: rank 10 of 16 running on i72600K
Hello world: rank 11 of 16 running on i72600K
Hello world: rank 12 of 16 running on i72600K
Hello world: rank 13 of 16 running on i72600K
Hello world: rank 14 of 16 running on i72600K
Hello world: rank 15 of 16 running on i72600K
Note, for some reason first attempt failed, second succeeded. Third attempt succeeded.
Any thoughts?
Jim Dempsey
James_T_Intel
Do you have anything in the Windows Event Viewer indicating problems at the time of the failed run.
jimdempseyatthecove
If that shows up again, I will look in the logs (both systems).
I think that may have occurred the first time after a re-boot of one of the systems. I haven't seen it since.
I may also have to re-enable the Firewall logging too.
Jim Dempsey
