Intel® MPI Library
IntelMPI over Mellanox 10GB RDMA chipset
Thierry_C_1
Principiante
759 Vistas
Hi
What is the best DAPL provider to used with IntelMPI 5.1  when running with a 10Gb RDMA chipsset from Mellanox?
Currently I'm using I_MPI_DAPL_PROVIDER=ofa-v2-scm-roe-mlx4_0-1
I added some others extra parameters to workaround the resource limitation that we have on the chip
  export I_MPI_DAPL_RDMA_RNDV_WRITE=on
   export I_MPI_RDMA_MAX_MSG_SIZE=1048576
Thierry
0 kudos
1 Responder
Artem_R_Intel1
Empleados
759 Vistas
Hello Thierry,
The exact DAPL provider which gives you the best performance may depend on many factors (certain MPI application, size of the MPI task, specific cluster environment and so on). You can try to vary the available on your system DAPL providers and choose the one with best results.
Responder
