Intel® MPI Library
2275 ディスカッション
Problem enabling 64 bit Fortran compilation on Windows using Intel OneAPI with Cmake on Windows
vishy
ビギナー
9,326件の閲覧回数
I am trying to enable 64 bit integer size for a sample hello world kind of Fortran test code, in an MPI setup.
OS: Windows 10
Compiler used: Intel OneAPI 2021.3.0
MPI: Intel MPI
There are 2 scenarios I tried to test,
  1. using a single line command to compile an executable directly, mpiifort -o test.exe -i8 test.f90
  2. using a CmakeLists file to compile the test with necessary Fortran 64 bit "-i8" option and find_package(MPI). I made sure MPI libraries are picked (impi.lib, libmpi_ilp64.lib) and MPI_Fortran_Compiler points to mpiifort
I use a test of determining the size of MPI_INTEGER using an API MPI_Type_size( ) to check if 64 bit environment is enabled for Fortran/MPI setup.
call MPI_Type_size(MPI_INTEGER, sz, ierrsiz)
print *, 'sizeof(MPI_INTEGER) ', sz
Scenario 1 prints correct size of 8 bytes (64 bit) Scenario 2 prints incorrect size of 4 bytes ( 32 bit)
I do use "-i8" option in Cmake build system to enable 64 bit environment. But MPI still seems to be 32 bit.
Attached files/build logs.
Kindly help.
ラベル(2)
0 件の賞賛
7 返答(返信)
VarshaS_Intel
モデレーター
9,293件の閲覧回数
Thanks for providing all the information. We are working on this internally and will get back to you soon.
Thanks & Regards
Varsha
Alina_S_Intel
モデレーター
9,255件の閲覧回数
Firstly, your Cmake uses our NextGen Fortran compiler (ifx.exe) while mpiifort refers to Intel Fortran Compiler Classic (ifort.exe). Please, note that ifx.exe is still in Beta and we recommend using it for openMP offload ONLY. For any other cases, please, continue using ifort. Add -DCMAKE_Fortran_COMPILER="ifort" macro to your cmake command line.
Source files are not identical and this is the reason for different results:
test.f90:
    integer i, size, rank, namelen, ierr, ISIZE
    character (len=MPI_MAX_PROCESSOR_NAME) :: name
    integer stat(MPI_STATUS_SIZE)
    INTEGER  :: sz
    INTEGER  :: ierrsiz
ISIZE = SIZEOF(rank)
print *, 'sizeof(INTEGER) = ', ISIZE
output:
 sizeof(INTEGER) =           8
 sizeof(MPI_INTEGER)           8
 sizeof(MPI_INTEGER4)           4
 sizeof(MPI_INTEGER8)           8
 Hello world: rank           0 of
sizeof(integer) =   8 is expected for  INTEGER  :: rank
-i8 option changes  sizeof(INTEGER) to 8 and I see 4 without this option. (mpiifort test.f90 VS mpiifort -i8 test.f90)
test_cmakelists_example.f90:
    integer i, ISIZE
INTEGER(4)  :: sz
    INTEGER(4)  :: ierr, size, rank, namelen
    INTEGER(4)  :: ierrsiz
print *, 'sizeof(integer) = ', ISIZE
output for test_cmakelists_example.exe:
 sizeof(integer) =           4
 sizeof(MPI_INTEGER)      4
 Hello world: rank      0 of      1 running on
What I see here when building without Cmake:
>mpiifort test_cmakelists_example.f90
mpifc.bat for the Intel(R) MPI Library 2021.4 for Windows*
Copyright Intel Corporation.
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.4.0 Build 20210910_000000
Copyright (C) 1985-2021 Intel Corporation. All rights reserved.
Microsoft (R) Incremental Linker Version 14.29.30040.0
Copyright (C) Microsoft Corporation. All rights reserved.
-out:test_cmakelists_example.exe
-subsystem:console
"/LIBPATH:C:\Program Files (x86)\Intel\oneAPI\mpi\latest\env\..\lib\release"
"/LIBPATH:C:\Program Files (x86)\Intel\oneAPI\mpi\latest\env\..\lib"
impi.lib
test_cmakelists_example.obj
And what I see when adding -i8:
-subsystem:console
impi.lib
C:\Users\ashadrin\Downloads\OSC\c05255486_f>mpiifort test_cmakelists_example.f90 -i8
test_cmakelists_example.f90(24): warning #6075: The data type of the actual argument does not match the definition.  [IERR]
    call MPI_INIT (ierr)
test_cmakelists_example.f90(26): warning #6075: The data type of the actual argument does not match the definition.  [SIZE]
    call MPI_COMM_SIZE (MPI_COMM_WORLD, size, ierr)
test_cmakelists_example.f90(26): warning #6075: The data type of the actual argument does not match the definition.  [IERR]
test_cmakelists_example.f90(27): warning #6075: The data type of the actual argument does not match the definition.  [RANK]
    call MPI_COMM_RANK (MPI_COMM_WORLD, rank, ierr)
test_cmakelists_example.f90(27): warning #6075: The data type of the actual argument does not match the definition.  [IERR]
test_cmakelists_example.f90(28): warning #6075: The data type of the actual argument does not match the definition.  [NAMELEN]
    call MPI_GET_PROCESSOR_NAME (name, namelen, ierr)
test_cmakelists_example.f90(28): warning #6075: The data type of the actual argument does not match the definition.  [IERR]
test_cmakelists_example.f90(30): warning #6075: The data type of the actual argument does not match the definition.  [SZ]
test_cmakelists_example.f90(30): warning #6075: The data type of the actual argument does not match the definition.  [IERRSIZ]
test_cmakelists_example.f90(32): warning #6075: The data type of the actual argument does not match the definition.  [SZ]
        call MPI_Type_size(MPI_INTEGER4, sz, ierrsiz)
test_cmakelists_example.f90(32): warning #6075: The data type of the actual argument does not match the definition.  [IERRSIZ]
test_cmakelists_example.f90(34): warning #6075: The data type of the actual argument does not match the definition.  [SZ]
        call MPI_Type_size(MPI_INTEGER8, sz, ierrsiz)
test_cmakelists_example.f90(34): warning #6075: The data type of the actual argument does not match the definition.  [IERRSIZ]
test_cmakelists_example.f90(59): warning #6075: The data type of the actual argument does not match the definition.  [IERR]
    call MPI_FINALIZE (ierr)
-subsystem:console
libmpi_ilp64.lib
impi.lib
vishy
ビギナー
9,240件の閲覧回数
Thanks for the reply.
I used the same test application for mpiifort and cmake based compilation. And configured "ifort.exe" for CMAKE_Fortran_COMPILER during CMake configuration in command line. The size of MPI_INTEGER when compiled using cmake results in 0 (Zero) instead of 8 bytes.
Following are the outputs for 2 scenarios:
output for mpiifort and i8 compilation on same test.f90:
cmd: mpiifort -o test.exe -i8 test.f90
 sizeof(sz) = 8
output for cmake based compilation on same test.f90:
cmd: cmake -S . -B out -G "Ninja" -DCMAKE_Fortran_COMPILER="ifort.exe" & cmake --build out --verbose
<attached cmakelists file and test.f90>
sizeof(sz) = 8
sizeof(MPI_INTEGER) 0
sizeof(MPI_INTEGER4) 0
sizeof(MPI_INTEGER8) 0
Hello world: rank 0 of 0 running on
Alina_S_Intel
モデレーター
9,193件の閲覧回数
I've noticed that I recommended you using  -DCMAKE_Fortran_COMPILER="ifort.exe". However, for MPI applications we are using mpiiforr wrapper, so the correct macro here should be -DCMAKE_Fortran_COMPILER="mpiifort.bat". Sorry for the confusion.
It seems that INCLUDE_DIRECTORIES(${MPI_INCLUDE_PATH}) in the CMakeLists.txt is the reason for MPI_INTEGER = 0. I've removed it and got the same result as for 'mpiifort -i8 test.f90':
mpiexec -n 1 out/test.exe
 sizeof(sz) =           8
You can check it from cmd using 'mpiifort -I\ -I"C:\Program Files (x86)\Intel\oneAPI\mpi\latest\include" -i8 test.f90'. It should give you 0 instead of 8 \ 4 for MPI_INTEGERs. Then remove -I\ -I"C:\Program Files (x86)\Intel\oneAPI\mpi\latest\include" the result should be correct.
vishy
ビギナー
9,127件の閲覧回数
I was able to reproduce the steps above and got 8 byte size for MPI_INTEGER using CMake build system. Instead of using -DCMAKE_Fortran_COMPILER="mpiifort.bat" in command line, I added a set command in CMakeLists.txt : "set(CMAKE_Fortran_COMPILER ${MPI_Fortran_COMPILER})"
I was able to observe 2 weird behaviors using CMake build system:
1. "find_package(MPI COMPONENTS C Fortran REQUIRED)" does not automatically find the required Intel MPI's ILP64 library. By default, only impi.lib is populated under MPI_C_LIBRARIES. For MPI ILP64 (i.e., 8 byte printing of MPI_INTEGER), the libraries need to be linked in correct order as follows: libmpi_ilp64.lib;impi.lib. This, I achieve by manually forcing the variable "MPI_C_LIBRARIES" as used in CMakeLists.txt. Why cant find_package() command do the necessary work?
2. The line in CMakeLists.txt < add_definitions("-DInt=__int64" "-DUInt=unsigned __int64" "-i8" "-i8") >,  has "-i8" twice and is used intentionally. For some unknown reason, if I remove the duplicate "i8" and have a single mention,  size of MPI_INTEGER drops to 0 (zero) from 8
Attaching the CmakeLists.txt and build logs.
vishy
ビギナー
8,998件の閲覧回数
Kindly help me wrt above query, where CMake does not populate MPI liubraries automatically using find_package(MPI ..) command and also the behavior I see in using "-i8" flag.
This behavior is especially observed in Windows CMake build.
Alina_S_Intel
モデレーター
8,862件の閲覧回数
Apologies for taking so long to respond to your request. The investigation took more time than we expected.
  1. The issue with find_package is a known issue and it is on the Cmake side. Please, follow this thread to learn more and track the progress https://gitlab.kitware.com/cmake/cmake/-/issues/19427
  2. In your latest CmakeLists, you passed -i8 it to add_definitions("-DInt=__int64" "-DUInt=unsigned __int64" "-i8" "-i8"). However, add_definitions is for preprocessor definitions not for compiler options. Please, use target_compile_options(test PUBLIC ${FORTRAN_FLAG_INT64} "-ilp64" "-i8") instead.
返信
