Intel® MPI Library
ntel_Parallel_Studio_XE_Cluster_Edition_2019_Update4_Linux_ubuntu18.04
ab1
Débutant
6 123 Visites
Sir
the installed version of ifort is 19.0.4.243 on ubuntu 18.04.  the intel parallel studio xe (clusters) 2019 is the version
i am getting difficulty while compiling ARPACk-NG. It was downloaded from https://github.com/opencollab/arpack-ng/releases
i am following commands mentioned in read.md file to compile ARPACK-NG using CMake functionality:
    $ mkdir build
    $ cd build
    $ cmake -D EXAMPLES=ON -D MPI=ON -D BUILD_SHARED_LIBS=ON ..
    $ make
    $ make install
it is expected to build everything including examples and parallel support (with MPI).
-- Detecting Fortran/C Interface - Failed to compile
CMake Warning (dev) at /usr/share/cmake-3.10/Modules/FortranCInterface.cmake:309 (message):
  No FortranCInterface mangling known for sgemm
  The Fortran compiler:
    /opt/intel/compilers_and_libraries_2019.4.243/linux/mpi/intel64/bin/mpiifort
  and the C compiler:
    /opt/intel/compilers_and_libraries_2019.4.243/linux/bin/intel64/icc
  failed to compile a simple test project using both languages.
my bashfile has
   source /opt/intel/compilers_and_libraries_2019/linux/bin/compilervars.sh intel64
    source /opt/intel/compilers_and_libraries_2019.4.243/linux/mkl/bin/mklvars.sh intel64 ilp64 mod
  export CMAKE_INCLUDE_PATH=/opt/intel/compilers_and_libraries_2019.4.243/linux/mkl/include
 export CMAKE_LIBRARY_PATH=/opt/intel/compilers_and_libraries_2019.4.243/linux/mkl/lib/intel64:/opt/intel/compilers_and_libraries_2019.4.243/linux/compiler/lib/intel64
 export LD_LIBRARY_PATH=$CMAKE_LIBRARY_PATH:$LD_LIBRARY_PATH
    export MKLROOT=/opt/intel/mkl
       export FCFLAGS=-i8
     export FFLAGS="-i8"
   export CC=$(which icc)
    export CXX=$(which icpc)
    export FC=$(which mpiifort)
kindly let me know where i am making a mistake.
thanks
ab
0 Compliments
PrasanthD_intel
Modérateur
6 123 Visites
Hi Vardaan,
I have provided you links for steps on how to load intel libraries and compilers you want use.
Here i am again providing the steps to load compilers(icc,mkl,mpi) you need to build your project. Please follow the below steps and confirm:
By default, <install_dir> is:
For root users: /opt/intel/
For non-root users: $HOME/intel/
1)Intel C Compiler/Fortran compiler
source <install_dir>/compilers_and_libraries_2020.<update number>.<package number>/linux/bin/compilervars.sh <ia32|intel64>
2)Intel MPI
source <install_dir>/compilers_and_libraries_<version>/linux/mpi/mpivars.sh
https://software.intel.com/en-us/get-started-with-mpi-for-linux
3) Intel MKL
source <install_dir>/compilers_and_libraries_<version>/linux/mkl/bin/mklvars.sh  <intel64 mod ilp64>
https://software.intel.com/en-us/onemkl-linux-developer-guide-scripts-to-set-environment-variables
https://software.intel.com/en-us/mkl-macos-developer-guide-using-the-ilp64-interface-vs-lp64-interface
After loading these scripts set these environment variables to use intel compilers instead of GNU compilers
These scripts sets all the required environment variables required for intel compilers.
Let me know if you face any errors
Prasanth
Voir la solution dans l'envoi d'origine
0 Compliments
13 Réponses
PrasanthD_intel
Modérateur
6 123 Visites
We have tried to reproduce the issue and the cmake ran successfully.
The issue you might be facing is the required impi and fortan compilers are not properly loaded.
Try sourcing the latest version of impi and fortran again and run the cmake.
source /opt/intel/compilers_and_libraries_<version>/linux/bin/compilervars.sh intel64
source <installdir>/intel64/bin/mpivars.sh
Could you please tell me the output of which mpiifort.
Prasanth
0 Compliments
PrasanthD_intel
Modérateur
6 123 Visites
Has the given solution worked for you, are you able to run cmake successfully.
Do let us know.
Reach out to us if you need any further help.
Prasanth
0 Compliments
sahgal__vardaan
Débutant
6 123 Visites
Thanks prashanth
I tried to compile cmake -D EXAMPLES=ON -D INTERFACE64=ON -D MPI=ON -D BUILD_SHARED_LIBS=ON ..
however i am not sure if it has correctly compiled . I am not able to find detailed like integer size / 64 bit interface in build output
2   how can i get arpack.a files. i know ar q libarpack.a *.o will create archives but the issue is .f files are scattered in several directories like src/ util/ parpack.....\  which one should i consider if its sequentially compiled or using MPI
thanks
0 Compliments
PrasanthD_intel
Modérateur
6 123 Visites
Hi Vardaan,
1)I am attaching my cmake output ,here you can see from the highlighted line
 INTERFACE64 :1
The 64-bit integer interface (ILP64) for ARPACK, BLAS and LAPACK is set to 1.  Are you looking for this?integer64.png
2)Regarding the second point , could you please rephrase the question with more information of what you want.
Prasanth
0 Compliments
sahgal__vardaan
Débutant
6 123 Visites
Thanks Prashanth for all the pains taken and presenting in a more simple form. I loved the pics attached.
my output differs from yours in several ways
-- MPIFC:                            blank wheras it mentions in your output
-- BLAS:
-- link: /usr/lib/x86_64-linux-gnu/libopenblas.so
-- LAPACK:
why is it so ? i understand we are using different compilers. Though I am using intel but i am not getting  same files (.so) as yours. there is no intel file ? is it because of environment settings ? how can  get same as that yours.  I strongly feel mixing is taking place which is affecting me later. It appears I am not using intel mkl libraries .....
My 2nd question is     I require archive file of arpack  ie  libarpack.a.a files
The Cmake command does not produce libarpack.a file (if i am not mistaken). it needs to be created manually using ar q libarpack.a *.o
my concern is  the .o files are in SRC, UTIL and Parpack directories and may also be elsewhere ARPACK-NG folder. which folder should i consider if i am working with MPI/64 bit interface with MPI=ON
2b   what is parapck
3   If I am compiling using simple ifort (without mpi) shoud i keep MPI=0 or OFF   and subsquently do i need parpack files
deepest regards
vs
0 Compliments
PrasanthD_intel
Modérateur
6 123 Visites
Hi Vardaan,
1) The BLAS and LAPACk comes with intel mkl.  As you have parallel studio installed mkl is included in that.
  Please check your mkl installation by following below link:
   https://software.intel.com/en-us/onemkl-linux-developer-guide-checking-your-installation
  Set the environment variables by running the scripts as mentioned in the below link:
  https://software.intel.com/en-us/onemkl-linux-developer-guide-setting-environment-variables
2) The PARPACK  as mentioned in the readme.md file means Parallel ARPACK routines. The subroutines invloving MPI are considered as parallel and placed under PARPACK . If you want to use MPI subroutines you have to include the *.o files in PARPACK in the static library you are creating.
3) If you do not want the MPI subroutines you can exclude them by setting a flag in CMAKE  -D MPI=OFF which will disable the parallel support and        PARPACK will not be created.
If your initial query is resolved please raise a new thread for any further questions.
Prasanth
0 Compliments
sahgal__vardaan
Débutant
6 123 Visites
hi Prashanth
My simple query is what commands do i need to compile ARPACk using interl compiler and MKL libraries...
by defaults it is taking GNU libraries. example: to test arpack with sequential ILP64 MKL assuming you use gnu compilers
    ```$ ./bootstrap
    $ export FFLAGS='-I/usr/include/mkl'
    $ export FCFLAGS='-I/usr/include/mkl'
    $ export LIBS='-Wl,--no-as-needed -lmkl_sequential -lmkl_core -lpthread -lm -ldl'
    $ export INTERFACE64=1
    $ ./configure --with-blas=mkl_gf_ilp64 --with-lapack=mkl_gf_ilp64
    $ make all check```
How to use INTEL MLL LIb
The sceenshot that you sent, seems the RPACK was compiled using MKL libraries.
thanks
vs
0 Compliments
PrasanthD_intel
Modérateur
6 124 Visites
Hi Vardaan,
2)Intel MPI
3) Intel MKL
Prasanth
0 Compliments
ab1
Débutant
6 123 Visites
Dwadasi, Prasanth (Intel) wrote:
Hi Vardaan,
 INTERFACE64 :1
Prasanth
can you pl expalin how do you get link mentioned in MPIFC ?I coud not get it
thanks
0 Compliments
ab1
Débutant
6 123 Visites
Thanks Prashanth for the reply which i was looking for. It is very useful for a fresher like me.
Pl dont mind, if have 2 simple clarifications
1  Interface Libraries and Modules page 53   of the link
https://software.intel.com/sites/default/files/mkl-2020-developer-guide-mac.pdf
libmkl_blas95_ilp64.a                        Fortran 95 wrappers for BLAS (BLAS95) supporting LP64interface.
libmkl_lapack95_ilp64.a                    Fortran 95 wrappers for LAPACK (LAPACK95) supporting ILP64interface.
is it correct description given in above link blas95_ilp     is for LP64 interface !  though it has ilp
2 Defaults MKLROOT refers to link =/opt/intel/mkl     or    /opt/intel/compilers_and_libraries_2019.40.243/linux/mkl in my case ?
thanks for being so patient and helping me
vs
0 Compliments
PrasanthD_intel
Modérateur
6 123 Visites
Hi Vardaan,
1)I don't have a cluster edition of Parallel Studio so the MPI that comes with it does not include Fortran support. I have installed IMPI separately that's why the MPIFC is different from yours.
2)Looks like there is a mistake in the documentation the descriptions got reversed it seems.
3)The default MKLROOT for Parallel Studio is /opt/intel/compilers_and_libraries_2019.40.243/linux/mkl which was set while you source the mkl scripts.
Are you able to build your project now, if so can we close this thread?
Please raise a new thread if your initial query is resolved,
Prasanth
0 Compliments
PrasanthD_intel
Modérateur
6 123 Visites
Is the build successful? Are you facing any errors?
Let us know if you need any help.
Prasanth
0 Compliments
PrasanthD_intel
Modérateur
6 123 Visites
We are closing this assuming your problem is resolved.
Please raise a new thread for any further queries.
Prasanth
0 Compliments
Répondre
