Shuts down but all LED Stay On including skull
This problem usually happens after the computer being used for a few hours I have to pull the power then it works as normal and will fully shut down correctly for a while .
All drivers are updated any suggestions please
Nor would it; you are actually seeing a shutdown issue, not a LED issue (which is just a symptom). This is likely an issue related to the ACPI implementation within the BIOS, since this implements the platform's physical shutdown operation. @WannerG_Intel: This one likely has to go back to the BIOS Engineers for analysis - hopefully a way can be found to reproduce it consistently so that it can be root-caused.
Please try the following procedure to perform full shutdown from Windows:
Step 1: Open Start menu, select Power button.
Step 2: Press and hold the Shift key on keyboard, while clicking on Shut down, and then release the Shift key to perform a full shutdown.
Leon
Thanks Leon, at first I thought this was going to be the solution it sounded like the answer however I am still experiencing the same problems
Hi here is the detailed scan thank you
hi and thanks for your answers,
I am still experiencing the exact same problem so I will run the utility and send the report
Hi @STayl17
- Please set bios settings to default (at least for testing). While in bios, press F9 followed by "Y" and F10 confirmed by "Y".
- If you have installed LED Manager for Intel NUC, please uninstall it (just for test).
Leon
Thank you I have tried everything you have just mentioned but the problem still comes back it's not every single time it's quite random
Hello STayl17,
Were you able to follow the recommendations provided?
If the issue persists, please run the Intel® System Support Utility (Intel® SSU) and attach the report to this thread.
- Download the Intel® System Support Utility and save the application in your computer.
- Open the application and click "Scan" to see system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
Wanner G.
Under Contract to Intel Corporation
Hello STayl17,
We will look into this issue and get back to you soon.
Could you please attach the Intel® SSU report requested in previous posts?
Wanner G.
Hello STayl17,
If you need further assistance, please let us know.
Wanner G.
I have this same problem, the lights stay on after shutdown. What could cause this?
Mine sometimes does that too I have tried everything suggested accept the diagnosis report
Hello STayl17,
If you need further assistance, please contact us back.
Wanner G.
I'm having the same problem too. I'm on latest BIOS & drivers version. Any solution to this problem?.TQ
@FAbdu,
Every case is different. Please open your own conversation and we will discuss your issue there.
Hello STayl17,
Thank you for attaching the report requested.
First, Load default BIOS settings.
1. Press F2 during boot to enter BIOS Setup.
2. Press F9 to set defaults.
3. Press F10 to save and exit BIOS.
Test if the issue persists. If it does, let us know if you are using the LED Manager for Intel® NUC.
Wanner G.
