Community
cancel
Showing results for
Search instead for
Did you mean:
DErle
NUC7I3BNK: Crucial MX300 275GB SATA M.2 SSD not recognized
Bought an Intel NUC7I3BNK and a Crucial MX300 275GB SATA M.2 2280SS SSD.
Although it is listed as compatible at http://www.crucial.de/deu/de/nuc7i3bnk/CT9857401 Crucial MX300 Interne SSD 275 GB M.2 2280SS CT9857401 | NUC7i3BNK | Crucial DE , the SSD is not recognized in the BIOS.
Already updated the BIOS to the latest version 0057. Details from BIOS setup:
- Advanced -> Devices -> SATA : SATA is active. SATA Port shows "[Not Installed]"
- Advanced -> Devices -> PCI : M.2 Slot is active. M.2 Slot shows "Not Populated"
I have no other M.2 SSD available to test if the problem is related to the SSD or to the NUC.
Any suggestions?
Thanks in advance.
Dirk
n_scott_pearson
Super User Retired Employee
Have you tried removing it and then putting it back in? Sometimes a reseating works wonders...
DErle
Thanks Scott.
In fact, I ordered another SSD (Western Digital Green) and this one was recognized without any problem.
So it seems the Crucial SSD I received from Amazon is damaged.
