I have a brand new NUC7PJYH, put in 2x 4GB Crucial DDR4 CL17 SODIMM Rams and a crucial 120GB SSD into it.
I wanted to use it as a media center, but it's not possible. Mostly, if YouTube runs vor 5 to 10 mins, Netflix for about 5 mins oder Amazon for 1 to 2 minutes, i will get an BSOD/Bluescreen.
I had several reasons like the typical:
- NO_EXCEPTION_HANDLING_SUPPORT
- MEMORY_MANAGEMENT
- BAD_SYSTEM_CONFIG_INFO
- and some more
I'm using a ACER Beamer at HDMI Port 1, I also tried port 2, i tried different RAM models (Ballistics, GEIL), i tried another Monitor etc etc, I updated to the new Intel BETA Drivers 6448, but nothing helps.
I also re installed Win 10 Educational 4 times, always the same, after the Intel graphics driver is installed.
Does anyone have further ideas? I give up after many weeks of troubleshooting.
Greetings,
Dirk
If you are not using wireless or bluetooth, try disabling wireless and bluetooth (if present) adapters in Windows. You'll find a link to do this change under "Change adapter settings" in Network and Internet Settings.
If this fixes your blue screening, suspect badly behaving wireless/bluetooth drivers.
Hey rgord1
I found that out yesterday, you're absolutely right! Now I have an external wifi Adapter, it works fine without in the built-in WiFi. Found that problem in many forums, but it's a little scandal that Intel still doesn't seem to have any solution for this...
Anyone found a solution until today to use the internal Wifi?
Greetings!
You could try this procedure, suggested by n.scott.pearson:
https://forums.intel.com/s/question/0D70P0000069GhhSAE
Best, Peter
