I use Hyper-V server running on a Intel NUC Pro 9,
The first Ethernet is correctly install and works,
But the Hyper-V doesn't install driver for the second Ethernet,
When I use Powershell Get-pnpDevice command, I see that second Ethernet return a error,
How can I fix it ?
Pascal
Hello @Pascal06
In regards to this behavior, it is worth mentioning that the operating system (OS) supported by Intel® NUCs Pro with 9th Generation Intel® Core™ Processors are Windows® 10 64-bit and in some models, Windows® Server 2019 with limited support, for instance, no drivers available for some components. For more details, please review this article: Supported Operating Systems for Intel® NUC Products.
In addition, Hyper-V Server* has not been validated for Intel® NUCs, so our recommendation is to check this further with the OS developer for further assistance, recommendations, generic drivers, and possible workarounds if available.
Perhaps other community peers may provide additional suggestions.
Andrew G.
Hello Pascal06
We have not heard back from you so we will proceed to close this inquiry now from our end. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
