Intel® Optane™ Memory
Annonces
1390 Discussions
Dell inspiron 5593 how do i accelerate my intel optane memory
kweniiii
5 847 Visites
hello, how do i accelerate my intel optane memory it keeps saying "you have no valid disk pair in your system"
i'm new to laptops so i don't really know how this works??
0 Compliments
AlHill
Super utilisateur
5 843 Visites
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Voir la solution dans l'envoi d'origine
16 Réponses
kweniiii
5 846 Visites
do i have to enable it? i search on google on how to but when i search for Intel Rapid Storage it doesn't appear. Do i not i have it?
0 Compliments
AlHill
Super utilisateur
5 844 Visites
kweniiii
5 832 Visites
0 Compliments
kweniiii
5 828 Visites
here is my system information
0 Compliments
JosafathB_Intel
Modérateur
5 816 Visites
Hello, kweniiii,
Thank you for contacting Intel® Memory and Storage support.
We do not see any file attached to your post, would you mind to try again to upload the SSU logs, to review your current configuration, and to continue with the troubleshooting.
We will be looking forward to your reply.
Josh B.
A Contingent Worker at Intel®
0 Compliments
JosafathB_Intel
Modérateur
5 801 Visites
Hello, kweniiii,
We were reviewing your community thread related to your Intel® Optane™ Memory Series, and we would like to know if you were able to review our previous post and if you needed further assistance.
Have a nice day.
Best regards.
Josh B.
0 Compliments
JosafathB_Intel
Modérateur
5 782 Visites
Hello, kweniiii,
We were reviewing your community thread related to your Intel® Optane™ Memory Series, and we have not heard back from you in a while, so we will proceed to close this inquiry now.
If you need further assistance, please post a new question.
Josh B.
0 Compliments
Muhammad_Ahsan_Tariq
5 756 Visites
Hi @JosafathB_Intel, I am facing the same problem.I am attaching my system info. Kindly guide me.
Thanks!
0 Compliments
5 753 Visites
Sorry, attatched the old file previously.
Here is the new one. @JosafathB_Intel
0 Compliments
LeonWaksman
Super utilisateur
5 748 Visites
Hi @Muhammad_Ahsan_Tariq
1. You are not facing the same problem, since your system may be different (although you have the same laptop model).
2. From the attached SSU report I can't see that you have an Optane Memory installed in your laptop. In addition, you have a Toshiba 512 GB NVMe SSD and the NVMe SSD can't be and need not to be accelerated since this kind of drive is high performance drive. Only SATA HDD/SSD can be accelerated.
Leon
5 740 Visites
0 Compliments
5 739 Visites
I changed my drive from AHCI to RAID mode and reinstalled my windows.
Should I revert it to AHCI mode? @LeonWaksman
0 Compliments
LeonWaksman
Super utilisateur
5 717 Visites
1. Yes that's right you should change your SATA mode back to AHCI:
2. In order to change SATA Mode without destroying Windows boot, Windows must be set to SAFE Boot Mode. While in Windows, press Windows key + r. Run msconfig .  Chose Boot tab and enable Safe boot. Reboot your system.
3. During system boot enter Bios.
4. Now you can change the SATA mode to AHCI. Save the setting  and boot into windows in SAFE mode. Disregard the warning you will see.
5. While in Windows, press Windows key + r. Run msconfig. Chose Boot tab and uncheck Safe boot
Leon
5 686 Visites
Did it. Thanks!
I also wanted to ask that when I move 4k content to my external Seagate hard drive 3.0 (same port in laptop),the transfer speed is pathetic,10 mb per sec.Is there any solution to it? @LeonWaksman
0 Compliments
LeonWaksman
Super utilisateur
5 681 Visites
There could be different reason for such low transfer speed. However, in most cases not the USB connection is the cause for that, but the write/read speed of your external drive. I'm using as an external drive WD Elements 3 GB drive and the transfer speed is about 100 MB/s
Leon
5 672 Visites
0 Compliments
Répondre
