Intel® Optane™ Memory
告知
1387 ディスカッション
Dell inspiron 5593 how do i accelerate my intel optane memory
kweniiii
初心者
5,635件の閲覧回数
hello, how do i accelerate my intel optane memory it keeps saying "you have no valid disk pair in your system"
i'm new to laptops so i don't really know how this works??
0 件の賞賛
1 解決策
AlHill
スーパーユーザー
5,631件の閲覧回数
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
元の投稿で解決策を見る
16 返答(返信)
kweniiii
初心者
5,634件の閲覧回数
do i have to enable it? i search on google on how to but when i search for Intel Rapid Storage it doesn't appear. Do i not i have it?
AlHill
スーパーユーザー
5,632件の閲覧回数
kweniiii
初心者
5,620件の閲覧回数
kweniiii
初心者
5,616件の閲覧回数
here is my system information
JosafathB_Intel
モデレーター
5,604件の閲覧回数
Hello, kweniiii,
Thank you for contacting Intel® Memory and Storage support.
We do not see any file attached to your post, would you mind to try again to upload the SSU logs, to review your current configuration, and to continue with the troubleshooting.
We will be looking forward to your reply.
Josh B.
A Contingent Worker at Intel®
JosafathB_Intel
モデレーター
5,589件の閲覧回数
Hello, kweniiii,
We were reviewing your community thread related to your Intel® Optane™ Memory Series, and we would like to know if you were able to review our previous post and if you needed further assistance.
Have a nice day.
Best regards.
Josh B.
JosafathB_Intel
モデレーター
5,570件の閲覧回数
Hello, kweniiii,
We were reviewing your community thread related to your Intel® Optane™ Memory Series, and we have not heard back from you in a while, so we will proceed to close this inquiry now.
If you need further assistance, please post a new question.
Josh B.
Muhammad_Ahsan_Tariq
5,544件の閲覧回数
Hi @JosafathB_Intel, I am facing the same problem.I am attaching my system info. Kindly guide me.
Thanks!
5,541件の閲覧回数
Sorry, attatched the old file previously.
Here is the new one. @JosafathB_Intel
LeonWaksman
スーパーユーザー
5,536件の閲覧回数
Hi @Muhammad_Ahsan_Tariq
1. You are not facing the same problem, since your system may be different (although you have the same laptop model).
2. From the attached SSU report I can't see that you have an Optane Memory installed in your laptop. In addition, you have a Toshiba 512 GB NVMe SSD and the NVMe SSD can't be and need not to be accelerated since this kind of drive is high performance drive. Only SATA HDD/SSD can be accelerated.
Leon
5,528件の閲覧回数
5,527件の閲覧回数
I changed my drive from AHCI to RAID mode and reinstalled my windows.
Should I revert it to AHCI mode? @LeonWaksman
LeonWaksman
スーパーユーザー
5,505件の閲覧回数
1. Yes that's right you should change your SATA mode back to AHCI:
2. In order to change SATA Mode without destroying Windows boot, Windows must be set to SAFE Boot Mode. While in Windows, press Windows key + r. Run msconfig .  Chose Boot tab and enable Safe boot. Reboot your system.
3. During system boot enter Bios.
4. Now you can change the SATA mode to AHCI. Save the setting  and boot into windows in SAFE mode. Disregard the warning you will see.
5. While in Windows, press Windows key + r. Run msconfig. Chose Boot tab and uncheck Safe boot
Leon
5,474件の閲覧回数
Did it. Thanks!
I also wanted to ask that when I move 4k content to my external Seagate hard drive 3.0 (same port in laptop),the transfer speed is pathetic,10 mb per sec.Is there any solution to it? @LeonWaksman
LeonWaksman
スーパーユーザー
5,469件の閲覧回数
There could be different reason for such low transfer speed. However, in most cases not the USB connection is the cause for that, but the write/read speed of your external drive. I'm using as an external drive WD Elements 3 GB drive and the transfer speed is about 100 MB/s
Leon
5,460件の閲覧回数
返信
