Intel® Optane™ Memory
1388 Discussions
Error Code: 0xA008002D after update to Ver. 16.0.2.1086
SRend
Hello! After updating Intel Optane Memory software from ver.15.9.0.1015 to ver.16.0.2.1086 I received this error: Error Code: 0xA008002D. Unsupported System BIOS is set in Legacy Mode.
I was forced to downgrade back. Screenshots included.
Hello surr,
Thanks for posting in our communities. We understand that you're having issues with Intel® Optane™ Memory after installing the latest Intel® Rapid Storage Technology (Intel® RST) drivers (16.0.2.1086).
In order to better assist you, please provide us with following files:
- Intel® System Support Utility report.
1. https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-%3Fproduct%3D91600 Download the latest Intel® SSU.
2. Select to include "everything."
3. Name and save the report.
- Intel Optane logs located at C:\Users\[your_user_name]\Intel\Logs
The attach button is located at the lower right of the reply box.
Just to be clear, were you able to enable Intel Optane Memory acceleration after rolling back the driver to version (15.9.0.1015)?
Eugenio F.
SRend
Hello Eugenio.
Thanks for your answer.
1. Today I tried once again to update the program. The result is the same: the same error. failure.
report attached.
2. After rolling back the driver from 16.0.2.1086 to previous version (15.9.0.1015) acceleration was automatically enabled.
Hello surr,
Thanks for providing the Intel SSU report.
Checking the https://www.asrock.com/MB/Intel/Z270%20Extreme4/index.asp# Download motherboard's support website, we noticed the latest Intel RST/Optane memory driver version is 15.5.0.1015, they have not uploaded version 16.X so far.
We'll report the issue to the appropriate team. For now, please keep using the previous driver release and check the motherboard manufacturer website for BIOS and software updates.
Eugenio F.
SRend
Hello Eugenio.
The essence of the problem became clear to me.
Thanks for your help!
p.s. I forgot to send you Intel\logs
apparently no longer needed
