Intel® Optane™ Memory
1391 Discussions
Hi, I'm going to change my pc case and I would like to know if I have to disable my optane memory for switching it or if I can just switch my components in the other pc case.
APara19
AlHill
You are keepting the motherboard, memory, processor, and all the other goodies, and just moving to a different case? That SHOULD be no problem. However, I would disable it, and take a backup, then do the move, and then enable the optane, and put the backup aside for safe keeping.
Doc
AlHill
Doc
