Intel® Optane™ Memory
公告
1387 討論
I have a 500mb 900p and while reinstalling windows, I believe I deleted the partitions, causing the integrated optane memory to not function. Is there a way to recreate the native partitions?
bwalk15
初學者
2,533 檢視
0 積分
8 回應
AlHill
超級使用者
2,337 檢視
It is just "list partition" or "list part". You have partitionS, which is incorrect.
Doc
bwalk15
初學者
2,337 檢視
when i type list part or list partition, here's what comes up.
bwalk15
初學者
2,337 檢視
If it's helpful, here are the other commands I tried. If i recall, there used to be a 15gb partition for the integrated optane memory.
AlHill
超級使用者
2,337 檢視
You better be careful with Disk part.
LIST DISK
SEL DISK X
LIST PART
are the commands you should use and in that order.
Doc
bwalk15
初學者
2,337 檢視
Thank you. Here is the information. To be clear, when I reinstalled and installed the intel RST software, it says "your system appears to be intel optane memory ready and intel optane memory module is present, but no compatible disks to accelerate were detected on your computer. please install a compatible disk." the enable optane memory button is also grayed out. all of the BIOS settings are correct, I believe.
AlHill
超級使用者
2,337 檢視
We need more than just "I believe".
Doc
bwalk15
初學者
2,337 檢視
I didn't do anything out of the ordinary when I reinstalled. I did a UEFI usb windows reinstall and formatted from the pre-boot windows installer menu. I just allocated an extra 20mb of space to my only drive--some people said this fixed their issue but the issue still persists on my end.
Most of the screenshots I see of peoples' configuration shows SSD partition plus around 13gb of "optane memory" listed as a separate partition. Do I need to reinstall and create a separate partition for the SSD to be recognized as optane compatible? It appears that my system is recognizing the optane module but something is wrong with the interface between it and SSD.
BrusC_Intel
員工
2,337 檢視
Hello, bwalk15.
Good day,
Thank you for contacting the Intel Community Support and thank you Al Hill for your assistance.
It has been brought to my attention that this ticket has already been resolved via phone with one of our agents, I will proceed to close the thread now.
In case someone else is interested, the main reason for the error message being that Intel Optane Memory is designed to accelerate SATA drives (SSD or HDD) and just selected PCIe NVMe* Intel® SSD 6 Series with Intel® QLC 3D NAND.
Bruce C.
A Contingent Worker at Intel
回覆
