Intel® Optane™ Memory
1387 Discussions
I would like to ask that, Intel Rapid Storage and Optane Memory can not be install in a computer ?
AChun11
Hi sir, i want to ask that if my computer had install SSD and Intel Rapid Storage, but i also have bought the Intel Optane Memory for my HDD, once i install the Intel Optane Memory program, the system pop-out said that, i already install Intel Rapid storage, so Optane memory can not be install. By the way, my mother board is Aorus Master Z390, which is support Intel Optane Memory. Thanks
DiegoV_Intel
Hi AChun11,
Thank you for posting in the Intel® communities.
Both applications, the Intel® Optane™ Application and the Intel® RST Application includes the RST drivers, so if you have installed one of them and then you try to install the other one, you will get that error message because your system already has the drivers (even though they are different applications).
However, you can use both of them to configure and setup the Intel® Optane™ Memory, so if you already have the Intel® RST application, you can use it to setup the module. Just make sure you are using the latest version which is, at this time, the 16.8 version.
If you want, for some reason, to use the other application, you will have to uninstall the one that you have first, and then install the other one.
You can download both of them from the following sites:
I hope this information clarifies your concern.
Have a nice day.
Diego V.
Under Contract to Intel Corporation
DiegoV_Intel
Hi AChun11,
Have a nice day.
Diego V.
DiegoV_Intel
Hi AChun11, Just wondering if there is anything else I can help you, or if the information above answered your concern. Regards, Diego V. Intel Customer Support Technician Under Contract to Intel Corporation
