Intel® Optane™ Memory
1391 Discussions
More "No Compatible Disks" Help
QFurl
MSI Laptop GT75 8SG
  • i9-8950hk - might be problem but if so, its not self diagnosed as such.
  • Windows 10 home 1809 {17763.503}
Newest BIOS just flashed,
32gb Optane installed in m.2 Controller 1 port 3,
SSD with OS installed in m.2 Controller 1 port 1,
Optane is identified by all software correctly and as nvme
2 tb HDD from seagate installed in only Sata port.
  • 160 mb not in any partition
Bios set for Optane, not ACHI.
Intel Rapid storage technology recognizes optane and HDD, but not showing any "compatible drives"
Maybe Im REALLY unlucky and seagate doesn't like Optane?
ssu file attached
JosafathB_Intel
Hello QFur, Thank you for your reply, Based on the information you provided we noticed the following: • Your BIOS is set up in "Legacy" mode that is not compatible with Optane. • Your PC may not be Optane ready since we are not able to see in your OEM (original equipment manufacturer) website or your PC manual any indications that your equipment is Optane ready. We strongly advise you to contact MSI in order to get the proper BIOS configuration and drivers this in case that your PC is compatible with the Optane memory. We hope you find this information helpful. If you need further assistance please do not hesitate to contact us. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
n_scott_pearson
I use Optane with Seagate drives, so no to any dislike there.
QFurl
Dang. Was hoping it would be a simple answer like that.
JosafathB_Intel
Hello QFurl, Thank you for having contacted Intel® Technical Support. I was reviewing your community post and we would like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
QFurl
I do still need help, havent been able to figure anything out myself.​
JosafathB_Intel
JosafathB_Intel
Hello QFur, Thank you for having contacted Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello QFur, Thank you for having contacted Intel® Technical Support. I was reviewing your community post and we would like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
