Intel® Optane™ Memory
公告
1387 讨论
Optane memory error at install asking for a motherboard compatible
LLarr
初学者
2,985 次查看
it 7800 Processor
Gigabyte z370 Mbo
Installed Optane memory.
When trying to run the software Setup Optane memory
I get an error message
0 项奖励
9 回复数
员工
1,788 次查看
Hi motoadve,
Thank you for contacting our support community. We understand that you cannot enable the
Intel® Optane™ Memory Series in your system.
In order to better understand your situation, could you please provide us with the following information:
*Please download and run the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility. Run the scan selecting "Everything." Save this report and upload.
*Please attach the logs located here: C:\Users\[your user name]\Intel\Logs
*Could you please try this https://downloadcenter.intel.com/download/27400/Intel-Rapid-Storage-Technology-Intel-RST-?product=55005 software and let us know if you get the same error message.
We look forward to hearing back from you.
Junior M.
0 项奖励
LLarr
初学者
1,788 次查看
Hello, I tried the link you sent and get the same error.
I submited the requested info.
Also is here.
Should we continue via e mail or should I post on the forum?
Larry
0 项奖励
员工
1,788 次查看
Hi motoadve,
Thanks for the reply.
Based on the logs it seems that your BIOS is in Legacy mode.
We recommend you to follow the next steps in order to change the BIOS to UEFI:
*Make sure you have the latest BIOS update for the motherboard.
1- Backup all files on your system.
2- Make sure you have the Windows(R) 10 creators update installed on your system and convert the partition table from MBR to GPT with MBR2GPT.exe in order to allow the system to boot after the BIOS change, please follow the next steps:
A- Open Command Prompt with administrator privileges
B- Issue the following command: mbr2gpt.exe /convert /allowfullOS
3-Shut down and boot into your BIOS
4- Press F7 to go to the advanced mode.
5-Go to BIos and under the BIOS option check the following configuration:
-CSM Support: Disabled
6-Go to the peripherals and check the following configuration:
-SATA Mode Selection : "Intel RST Premium with Intel(R) Optane(TM) system acceleration".
-Use RST Legacy OROM: disabled.
-PCIe Storage Dev On Port # (the port number where Optane(TM) is connected): RST Controlled.
7-Press F10 to save and apply the changes.
8-Automatic repair may show up and it is expected.
9-Acess msconfig and uncheck the safe boot option restart
the system and try to enable Optane(TM).
Please let us know the outcome of the situation.
Junior M.
0 项奖励
员工
1,788 次查看
Hi motoadve,
We would like to know if you read our previous post. If you have any other questions, we'll be waiting for your response.
Junior M.
0 项奖励
LLarr
初学者
1,788 次查看
Yes, thank you , but seems very complicated, I thought it was just plug and play, so I will have a friend who is a computer expert come help me next week.
Will post the results.
0 项奖励
员工
1,788 次查看
Hi motoadve,
Thanks for the information provided.
Junior M.
0 项奖励
员工
1,788 次查看
Hi motoadve,
We haven't heard back from you in a while. Have you been able to resolve this issue?
Junior M.
0 项奖励
LLarr
初学者
1,788 次查看
My friend who is an IT guy came to help, after 2 hrs of trying he told me Windows 10 needed to be re installed.
I gave up and return the Optane memory, its way too complicated to setup.
And bought an M.2 SSD.
Thanks for the support and follow up
0 项奖励
员工
1,788 次查看
Hi motoadve,
We understand that you had a hard time setting up the Optane(TM) module so you returned it. Now, you have purchased an SSD instead.
If you have further questions then feel free to contact us again.
Junior M.
0 项奖励
回复
