Intel® Optane™ Memory
1391 Discussions
intel optane memory 32gb not detected
VGonz6
got installed in a new computer
the pc used to detected
installed driver and intel rapid storage
activated optane genie
and now its not detected on pc or bios at all
atached a txt with information of my pc
thank you
DiegoV_Intel
Hi VGonz6,
Thank you for posting in the Intel® communities.
I understand that you are not able to see the module in BIOS nor OS level, however I’m confused about if you had the Intel® Optane™ Memory setup before in this system. Could you please let me know if the module was working fine before, or if you did a system change like replacing the HDD or re-installing the Windows* OS?
I’ll be waiting for your response.
Have a nice day.
Diego V.
Santiago_A_Intel
Hello VGonz6, Thank you for having contacted Intel® Memory & Storage Support.  This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back.  Best regards, Santiago A. Intel® Customer Support Technician Under Contract to Intel Corporation
