Intel® Optane™ Memory
1391 Discussions
problem with intel optane memory in asus x411un
BEfen
Dear intel,
I used the asus x411un. After I instaled the module in motherboard, it doesn't detect in device manager. What's wrong ? I've follow the instruction very well
Hi Baysena,
After searching for the motherboard model you have, I noticed that you have an ASUS* laptop. The one that I found is the ASUS VivoBook 14 X411UN.
If you are indeed using this laptop or any other laptop, I recommend you to contact ASUS* directly to confirm if the laptop supports the Intel® Optane™ Memory.
There are details about this laptop in the following site , however there is no reference to the Intel® Optane™ Memory which probably means that the module is not supported: https://www.asus.com/Laptops/ASUS-VivoBook-14-X411UN/Features/ https://www.asus.com/Laptops/ASUS-VivoBook-14-X411UN/Features/
Have a nice day.
Diego V.
Hi Baysena,
I was wondering if you have received any response from ASUS* about the Intel® Optane™ Memory support in your laptop model.
Diego V.
