I have 4 drives, one is the OS and three are known bad drives in the server:
$ ls -la /dev/sd*
brw-rw---- 1 root disk 8, 0 Jan 3 19:56 /dev/sda
brw-rw---- 1 root disk 8, 1 Jan 3 19:56 /dev/sda1
brw-rw---- 1 root disk 8, 2 Jan 3 19:56 /dev/sda2
brw-rw---- 1 root disk 8, 16 Jan 3 21:49 /dev/sdb
brw-rw---- 1 root disk 8, 32 Jan 3 22:01 /dev/sdc
brw-rw---- 1 root disk 8, 48 Jan 3 22:01 /dev/sdd
The ssu.sh utility will only report on the good drive /dev/sda
連結已複製
Hi AOtt,
Thank you for posting in the Intel® communities.
According to the ssu.sh script, the drives included in the following location should be checked:
drives=$( eval "$lsPath" -1 /dev/[hs]d* "$stderr" | "$grepPath" -v "sd.[0-9][0-9]\?$" ) # Location where the script looks for the drives.
if [[ -z "$drives" ]] ; then
Title="${indent3}Drive:\"Not Available\""
else
for drive in $( "$echoPath" "$drives" )
do
# NOTE: virtual disks (like ISO files) are not mounted, and should be ignored.
# /proc/mounts is the place to look for what is mounted. any drive in this list
# that is not found here will be ignored.
isMounted=$( [ $( eval "$catPath /proc/mounts $stderr" | "$grepPath" "$drive" | "$wcPath" -l ) -gt 0 ] && "$echoPath" true || "$echoPath" false )
if [ "$isMounted" = false ] ; then
continue
fi
However, if the drive is not mounted, then the script will ignore it according the note in the script.
I hope this clarifies the inquiry.
Have a nice day.
Diego V.
Hi AOtt,
I would like to know if this information clarified your concern, or if there is anything else I can help you with.
Diego V.
Hi Andreas,
Sure, thank you for the clarification.
When working with Data Center drives, the best tool is the Intel® SSD DCT.
Please keep working on those support cases to avoid confusions. I will just share with you an User Guide about the Intel® SSD DCT in case you need to know how to get the specific data that you want from the drive: https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/Intel_SSD_DCT_3_0_x_User_Guide.pdf
Diego V.
